Fuel Gauge
Fuel Gauge
My fuel gauge (88 NA) always reads 3/4 full when the engine is running.
The actual reading when the ignition is first turned on is fairly accurate.
Gauge slowly goes to 3/4 once engine is started.
Ideas? Is there a voltage regulator in the Instrument Cluster?
simon123- Posts : 125
Re: Fuel Gauge
Common problem. Some say it has to do with poor grounds etc.
Jon fixed the fuel gauge on my '89 by simply resetting the needle:
I believe the GM voltage regulator is integrated into the alternator as was the 944 OEM Bosch unit.
simon123 wrote:Is there a voltage regulator in the Instrument Cluster?
944convert- Posts : 253
