» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
WANTED! Brey Krause R-1020 Harness Guide Bar
Post  RS Technic on Tue Apr 22, 2014 10:44 am
If someone has a harness bar they are no longer using or are willing to part with (you have wanted to upgrade to a full cage haven't you?) please let me know.
Thanks.
RS Technic
Re: WANTED! Brey Krause R-1020 Harness Guide Bar
Post  docwyte on Wed Apr 23, 2014 8:55 am
do yourself a favor and skip a harness bar. Get a real rollbar instead, along with proper seats an harnesses...
Post  RS Technic on Wed Apr 23, 2014 12:38 pm
I already have MOMO seats and Schroth harness. My plan was to completely remove the stock 3 points and just use the harness, using the bar as a better mount point and adding a little stiffening to the frame without having to drill, weld and such.
I click into a harness very often being in the aviation profession. I am going to use inertia locking reels to get some fore/aft freedom at the shoulders.
Is the bar ineffective, or worse, not a safety improvement?
Keep in mind I don't plan on racing, just DE events.
The car will be driven.
RS Technic
Post  docwyte on Wed Apr 23, 2014 12:45 pm
Harness bars are a complete waste of time and money. They add nothing to the safety of your car and arguably make things worse.
If you have fixed back seats and harnesses (5 or 6 point, not 4 point, right?) you want/need a true rollbar to make everything work in concert and protect you properly.
Post  RS Technic on Wed Apr 23, 2014 5:01 pm
Got it.
Valid points.
Thank you.
RS Technic
Post  944convert on Wed Apr 23, 2014 8:45 pm
RS Technic wrote:Keep in mind I don't plan on racing, just DE events.
If this is going to be mostly for street, starting with a bolt in harness bar makes sense to me.
Else, weld the doors shut while you're at it and just use the windows.  Razz
