» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
XSchop "Bigger Blacks" on Cayenne 330mm rotor adapters
Page 3 of 3 Previous  1, 2, 3
Re: XSchop "Bigger Blacks" on Cayenne 330mm rotor adapters
Post  FrostedFlakeJake on Tue Jan 19, 2016 1:53 pm
So switching to another type of rotor would only change the offset +/- the difference in rotor thickness where it mounts up to the hub which is likely very minimal (maybe a mm or two at most).
That's what i'm hoping! rabbit
I just haven't gotten the rotors yet so i don't know how thick they are there. But like we both said, probably isn't going to be that thick at that point.
Also the cayenne centering rotors are ~7.5 mm thick. Not exactly sure how they fit on hub because I haven't held them in my hand but I imagine that 7.5mm is how far the wheel will be pushed out.
FrostedFlakeJake
Post  xschop on Tue Jan 19, 2016 2:16 pm
Yes and no....1.5 to 2.0mm positive offset is the difference depending on Cayenne rotor mfr.
Reason...
Early hub offset is 74mm and the late NA hubs are 68mm to make up for the over-the-hub rotor difference.
Post  FrostedFlakeJake on Tue Jan 19, 2016 2:20 pm
Reason...
Ah that's good to hear. Thanks for the clarification Smile
FrostedFlakeJake
Post  xschop on Sun May 22, 2016 9:30 pm
I have another spare set of these. Will be the last ones I make.... and don't ask for the tech drawing because I never made one lol Very Happy
Post  smee on Wed Aug 31, 2016 12:51 pm
Xchop, not to side line the thread but are you still making the mounting plates for either the wilwood tandem MC or the tilton dual? (cannot send pms just yet). Thanks !
smee
