» Magnuson supercharged car?
» WTB: LS powered 968
» Poly engine mounts melted
» Intake choice
» JP's LS1 Conversion
944T Master Cylinder Feedback
Post  porschevls3 on Fri Apr 18, 2014 7:37 pm
I am looking for some previous experience and constructive feedback please....
my conversion is a ls3 track only car... the manual brakes are ok but certainly could be better. I am not interested in going electro or hydro boost at this time... car has big reds with track pads up front; and stock calipers with track pads in rear. pedal is high and hard.
here's my question... I believe the master cylinder is dual with 23mm bore to the front and 19mm bore to the rear? Can I reverse the setup - plumb the fronts to the 19mm bore and the rears to the 23mm bore? I am thinking while this might give me a bit more pedal travel, it should give me more line pressure to the front brakes.
will this work? pros and cons? thanks.
porschevls3
Re: 944T Master Cylinder Feedback
Post  99sierra4x4 on Sat Apr 19, 2014 8:46 am
I am not 100% sure without doing some math, the only thing I could see being a problem is that the Big Reds most likely have a larger pistons, thus requiring more volume of fluid from the MC. The other issue is with more volume then going to the back, you might be locking up the rear brakes before the fronts have time to come on. You may need to upgrade the proportioning valve.
99sierra4x4
