» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
968 brake line ID
968 brake line ID
Post  Jim7 on Fri Apr 18, 2014 8:27 am
HELP  !  The car is a 93 - 968 ABS car.  I got an electric boost Brake ABS setup and my problem is I don't know which of the cars lines are front or rear. One line is to the left of the OE master and the other to the right of it, both coming through the firewall.  I searched everywhere on-line and the only thing I can find is that they are in fact brake lines, duh.  Thanks in advance.
Jim7
Re: 968 brake line ID
Post  Admin on Fri Apr 18, 2014 10:50 am
Post a picture and I can locate it for you
Post  944-LT1 on Fri Apr 18, 2014 5:36 pm
Post  944convert on Fri Apr 18, 2014 7:02 pm
What is needed is to see the ABS pump's input and output ports.
Can anyone post them?
Post  948 on Sat Apr 19, 2014 7:59 am
This might help, it is for a 944 though. Section 45-1
Post  944convert on Sat Apr 19, 2014 11:12 am
From that link I found this:
The ABS pump is behind the right front wheel and it looks like you'll need to trace out the hard lines from 1 (to mc front axle port) and 2 (to mc rear axle port).
btw...4 shows the bias valve...I'm guessing the 968 has one.
I think the 968's windshield washer tank is also in the same void behind and above the right front wheel.
Post  Jim7 on Sat Apr 19, 2014 12:24 pm
Thanks everybody, the ABS pic should solve the problem.
Jim7
