throttle cable hook up?
Hi all,
I've got a TPC Stainless Steel Braided throttle cable 36" and........how does this hook up to an LS1?? It looks like you need a swagged end on the cable to sit in the slot of the throttle shaft? How does this cable install??
Seems like all the questions are coming after the engine is in. Big day today......I closed the hood!
Cheers,
Gord.
Cheers,
Gord.
murrayg- Posts : 105
Re: throttle cable hook up?
You can get the ends from Summit for a few $. Uses a set screw to hold the cable and mimics the crimped barrel end.
Search for cable ends...
Jack
Jack
P911P951- Posts : 48
