Mounting remote reservoirs for Master Cylinders (clutch and brake)
Should remote reservoirs be mounted above a Master Cylinder? If they are mounted below, is there an issue with trapping/introducing air into the hydraulic circuit?
My Wilwood dual-circuit brake MC will fit with the reservoirs mounted on the MC itself, but that leaves the clutch MC without one. I picked a remote reservoir kit from Jegs, and am trying to figure out where to put it. The clutch MC is really high on the firewall, which makes locating the reservoir problematic.
Johnny Johnny- Posts : 164
Re: Mounting remote reservoirs for Master Cylinders (clutch and brake)
Here's a 968...similar firewall / engine bay. Plenty of room with the LT1...
Here's a remote Clutch MC Res in an LS / 944...
The 968 setup is further away from headers, etc...better location IMHO.
gt1scca- Posts : 795
