Oil Pan capacity
Oil Pan capacity
Hi all,
I'm well underway with a LS1 early 944 conversion. Engine is in place, close in a few spots, but fits like a glove. I've purchased the TPC kit from a failed project in Ottawa, Canada and I believe it's an older kit, but I'm unsure this matters much. My question, what is the capacity of the oil pan? Its the pan with the welded oil filter fittings instead of the block on the new pans.
Gord.
Gord.
murrayg- Posts : 105
Re: Oil Pan capacity
I have the same oil pan, took about 6 quarts to fill. If its your first start, also take into account the oil lines, your remote filter mount and an oil cooler if applicable.
Techno Duck- Posts : 447
Yup, 6 quarts. However with my oil lines and oil cooler my total capacity is 8 quarts.
A full fill with everything drained on mine was around 8.5-9 quarts . I am using the FL-1A Motorcraft filter on mine which alone holds just under a quart. So moral of the story, buy a few extra quarts for your initial fill! I had to make a trip back for another 2 quarts.
