» Dual MC Mounting Bracket
Yesterday at 8:11 pm by 87944turbo
Yesterday at 7:50 pm by hp18racer
Yesterday at 5:20 pm by dougr944
» Need help! Car won’t start
Yesterday at 3:51 pm by jess2suityou
Yesterday at 9:44 am by keetle
» Brand new ls3 build
Yesterday at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Yesterday at 1:35 am by Porsche951toLS3
January 2019
78910111213
14151617181920
21222324252627
28293031
Clutch Slave Banjo Bolt--From RH kit
Post  944-v8 on Sat Mar 29, 2014 1:39 am
Does anyone know the particular clutch slave that came in the original RH kits. I need the Banjo Bolt. Went to NAAPA and they couldn't find any SAE or metric banjo or regular bolt that would thread in. If I can find the model of the car it came from I might be able to get a banjo bolt. If you know the size and pitch of the threads on the banjo bolt, that would probably work.
944-v8
Re: Clutch Slave Banjo Bolt--From RH kit
Post  944-LT1 on Sat Mar 29, 2014 7:52 am
For the LT engines, the clutch slave they supplied in the kit was from a 1988 Corvette.
Post  944-v8 on Sat Mar 29, 2014 3:18 pm
Thanks Lt1
944-v8
