» SBC conversion without hood scoop
xschop.....help ! EmptyThu May 16, 2019 1:46 pm by sharkey
» ABS brakes won’t bleed
xschop.....help ! EmptyWed May 15, 2019 7:04 pm by knucklehead12
xschop.....help ! EmptySat May 11, 2019 10:55 am by Rich L.
xschop.....help ! EmptyWed May 08, 2019 3:15 pm by lamrith
» Will this throw out bearing work?
xschop.....help ! EmptyWed May 08, 2019 2:48 pm by Admin
» LS Truck engines
xschop.....help ! EmptyWed May 08, 2019 1:42 pm by Admin
» Did anyone do a before and after weight?
xschop.....help ! EmptyWed May 08, 2019 9:12 am by chrenan
» LF: completed kit or mostly complete
xschop.....help ! EmptyMon May 06, 2019 12:36 pm by gamman
» Tuner in Houston
xschop.....help ! EmptyThu May 02, 2019 3:25 pm by JW1970
» k & N filter and intake boot
xschop.....help ! EmptyTue Apr 30, 2019 8:08 pm by JW1970
May 2019
6789101112
13141516171819
20212223242526
2728293031
xschop.....help !
xschop.....help ! Empty xschop.....help !
Post  area52 on Fri Mar 28, 2014 3:28 am
i have a project iv put together,and id like to know what options i have for upgrading the brakes,looking around on the forum i see youre the man in the know,
the set up currently is this -
911 3.0sc vacuum assist servo master cylinder
944 2.5 85' na front hubs with stock brakes
911 3.0sc rear arms & hubs with stock brakes
16" alloys but can run 17" if required
any advice would be greatly appreciated  Smile
area52
xschop.....help ! Empty Re: xschop.....help !
Post  xschop on Fri Mar 28, 2014 11:14 am
Have you tested/tried what you've got?
If you are building a Mack truck or a rock crawler, none of those components will work. Point is what are you building?
Post  area52 on Fri Mar 28, 2014 12:11 pm
its a 1965 volkswagen type 2 microbus fitted with a 3.0sc engine and gearbox for road use,the rear axle is 3.0sc 911 so all the OE porsche stuff attaches to it,the front hubs and rotors are 944 items mated to vwmicrobus spindles,the spindle is fitted with a carrier to accept the 85' 944 2.5 na calipers.i havent tried it yet as brakes havent been commisioned.i realise the current braking set up will be adequate but was hoping for something a little bit more trick / show off ?
area52
Post  xschop on Sat Mar 29, 2014 8:32 am
VHT
Post  area52 on Sat Mar 29, 2014 12:14 pm
what does VHT mean ?
area52
Post  xschop on Sun Mar 30, 2014 8:10 am
It's a very high temp engine/caliper paint. There are not many options for early hubs/spindles for bigger rotors and calipers. I do have a set of billet conversion hubs that allow over the hub rotors.Then any of the Big brake adapters will bolt right up.
Another guy was doing a bus a few months back. I would like to see a 4.8 or 5.3 dropped in one.
Post  money pit 951 on Sun Mar 30, 2014 9:06 am
Post some pictures of this frankenstein!
What's your projected weight? I'm wondering if you need to upgrade the brakes over what you have considering your weight and street speeds
money pit 951
money pit 951
