WHAT ENGINE IS THIS? EmptyYesterday at 11:51 am by geegeesbits@gmail.com
WHAT ENGINE IS THIS? EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
WHAT ENGINE IS THIS? EmptySun Jan 26, 2020 4:51 pm by j7wolfe
WHAT ENGINE IS THIS? EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
WHAT ENGINE IS THIS? EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
WHAT ENGINE IS THIS? EmptySat Jan 18, 2020 7:15 am by Rothaus
WHAT ENGINE IS THIS? EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
WHAT ENGINE IS THIS? EmptyThu Jan 16, 2020 2:11 am by Golten1986
WHAT ENGINE IS THIS? EmptyTue Jan 14, 2020 2:48 pm by Gumby
WHAT ENGINE IS THIS? EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
WHAT ENGINE IS THIS? Empty WHAT ENGINE IS THIS?
Post  944boonemobile on Wed Mar 26, 2014 8:11 pm
Chevrolet Performance 19210009 - Chevrolet Performance 350ci/330HP HO Turn-Key Engine Details
350ci HO Turn-Key Engine
Notes:
Accessory components arrive unassembled for ease of installation
Distributor with melonized steel gear must be used with long blocks & partial engines with steel camshafts, or engine damage will occur
Replacement Parts:
Block: 10105123
Crankshaft: 14088527
Connecting Rods: 10108688
Pistons: 12361371
Piston Rings: 14089025
Camshaft: 24502476
Timing Chain: 14087014
Cylinder Heads: 12558060
Intake Valves: 10241743 1.94"
Exhaust Valves: 12550901 1.50"
Valve Springs: 10212811
Rocker Arms: 10089648 1.5 ratio
Spark Plugs: R44TS
Serpentine Drive System: 12497698
This block is drilled and tapped for clutch linkage.
I'M NOT AN EXPERT. DOES ANYONE KNOW THAT ENGINE? WILL IT WORK IN THE 944? AND DO I NEED A DIFFERENT RADIATOR, MINE DOESNT WORK WELL AS IS WITH THE STOCK ENGINE, ALWAYS AT ABOUT 3/4 ON THE GAUGE AND IT GETS TO MAX SOMETIMES UP HILLS OR STOP AND GO TRAFFIC. THE CAR IS ON ITS LAST LEG AND I'M ABOUT TO DO WHATEVER I HAVE TO SO I CAN DRIVE IT FOR 20 MORE YEARS.
-JUST A MILITARY GUY THAT LOVES HIS OLD PORSCHE
944boonemobile
944boonemobile
WHAT ENGINE IS THIS? Empty Re: WHAT ENGINE IS THIS?
Post  99sierra4x4 on Wed Mar 26, 2014 8:19 pm
That's basically a chevy 350. Most people are doing an LS Swap. So LS1/LS2/LS3/LS6. They started the LS series engines around 1999. I am not sure if Eric is making swap kits for the older style 350's.
99sierra4x4
Post  944boonemobile on Wed Mar 26, 2014 8:26 pm
yeah, i knew the basic 350. i just didnt know if that was from the LT series or what. So the conversion kits on here (bellhousings, adapters, etc) might work with this? I was trying to keep it to a low 300HP so the torque was low and i could still use the stock torque and transaxle for a year or two until i can replace that if even needed.
944boonemobile
944boonemobile
Post  944-LT1 on Wed Mar 26, 2014 9:52 pm
Please post your topics in the correct sections of the board. Thanks!  Very Happy
Post  944boonemobile on Thu Mar 27, 2014 12:16 pm
I'm trying to understand this forum, is this not the right section? The engine I'm looking at is just a Small Block Chevy (I was pretty sure, but didn't know if was a LT series.) If I'm converting my 944 to this small block, which section should I use?
944boonemobile
944boonemobile
Post  944-LT1 on Thu Mar 27, 2014 2:25 pm
944boonemobile wrote:I'm trying to understand this forum, is this not the right section? The engine I'm looking at is just a Small Block Chevy (I was pretty sure, but didn't know if was a LT series.) If I'm converting my 944 to this small block, which section should I use?
It's in the correct section now because I moved it here from the Member Conversions area. The members section is reserved for people who wish to introduce themselves, their car and their plans as well as update their thread as the conversion progresses. Other than that, all posts have a particular section.
As always, please feel free to create your own thread in the "944hybrids Member Conversions" section and introduce yourself!
Besides that, the engine you posted looks to be designed for pre-1976 applications and so is just a standard 350 (non-LTx based). However, since the LT and standard 350 share the same mountings (bellhousing and motor mounts), all the conversion parts that work with the LT conversion will work with the standard 350. As far as I know, no one is making a "kit" for the LT engines anymore...you would have to contact texas performance concepts to see what your options may be.
WHAT ENGINE IS THIS? Empty thanks
Post  944boonemobile on Thu Mar 27, 2014 2:30 pm
thanks, i appreciate it.
944boonemobile
944boonemobile
