Clutch Slave Banjo Bolt--From RH kit EmptyYesterday at 6:12 am by Colibri Green
» NDog52's 1986 NA 5.3 Build
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 26, 2024 6:28 pm by Raymond-P
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 26, 2024 8:49 am by 948
Clutch Slave Banjo Bolt--From RH kit EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
Clutch Slave Banjo Bolt--From RH kit EmptyWed Mar 20, 2024 1:17 pm by Rob44
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
Clutch Slave Banjo Bolt--From RH kit EmptyTue Mar 12, 2024 12:12 pm by ndog52
Clutch Slave Banjo Bolt--From RH kit Empty Clutch Slave Banjo Bolt--From RH kit
Post  944-v8 Sat Mar 29, 2014 1:39 am
Does anyone know the particular clutch slave that came in the original RH kits. I need the Banjo Bolt. Went to NAAPA and they couldn't find any SAE or metric banjo or regular bolt that would thread in. If I can find the model of the car it came from I might be able to get a banjo bolt. If you know the size and pitch of the threads on the banjo bolt, that would probably work.
944-v8
Clutch Slave Banjo Bolt--From RH kit Empty Re: Clutch Slave Banjo Bolt--From RH kit
Post  944-LT1 Sat Mar 29, 2014 7:52 am
For the LT engines, the clutch slave they supplied in the kit was from a 1988 Corvette.
Post  944-v8 Sat Mar 29, 2014 3:18 pm
Thanks Lt1
944-v8
