Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
Billet Fuel Rails
Billet Fuel Rails
Post  xschop on Sat Mar 15, 2014 10:13 am
I have a pair of Red anodized billet rails for sale. They are new and were the exact ones I used on the 5.3 swap. These are better suited for the 5.3, 6.0 truck (short) injectors for figment. The taller LS1 injector bodies bottom out on the rails before the O-rings get a deep enough seat.... $ 80 shipped US48 and will come with SS mounting brackets. Just PM
Re: Billet Fuel Rails
Post  xschop on Mon Mar 17, 2014 12:35 pm
I may be getting another LS1 intake with cable throttle and factory style LS1 injectors. I'll post here as a full set-up. I found that the injectors I am using are Higher # aftermarket. So factory LS1 injectors do fit these billet rails better.
Post  visian2002 on Tue Mar 18, 2014 8:40 pm
I'll take the rails. I cannot PM. You will need to contact me via e-mail [You must be registered and logged in to see this link.]
visian2002
Post  xschop on Wed Mar 19, 2014 9:39 am
Sent msg. I'm leaving the braided crossover tube with them.
Post  xschop on Wed Mar 19, 2014 2:37 pm
Sold
Post  xschop on Fri Mar 21, 2014 10:55 am
I also left the -6an Inlet fitting and NPT end cap installed for you as I won't need them.
USPS PRIORITY INSURED # 1312 0250 0000 4469 4304
