» Dual MC Mounting Bracket
Yesterday at 10:02 pm by 948
» LS1 1st start
» Need help! Car won’t start
» Brand new ls3 build
» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
Geo metro booster/MC
Post  Jasonscottw on Sat Mar 01, 2014 9:45 pm
Anyone ever used a booster/MC from a geo metro?
I understand they are the smallest unit ever put into a production car.
I think the booster diameter is under 5". I'm unsure of the length but it's pretty stubby.
Anyone?
Pic @ link:
https://www.google.com/url?sa=i&source=images&cd=&docid=AVOyXJk7Uw54OM&tbnid=0bz6pakOViDVNM:&ved=&url=http%3A%2F%2Fwww.dhscs.com%2Ffalcon%2Fassy.html&ei=cacSU42EJ5PG0gGA2ICQBg&psig=AFQjCNG_ft6e9OSP5xxqZHbtkFqXtn-adg&ust=1393817842114464
Jasonscottw
Jasonscottw
Re: Geo metro booster/MC
Post  zeusrotty on Mon Mar 03, 2014 2:45 pm
That could be an option! I like it! What do you think Eric?
zeusrotty
Post  Jasonscottw on Mon Mar 03, 2014 5:04 pm
Tempted to buy one and try it.
Pretty cheap at U-pick yards.
Wish I knew how much available space there was available in the booster/MC area
with the LS installed . . . my engine is still on a stand.
Anyone?
Jasonscottw
Jasonscottw
Post  zeusrotty on Mon Mar 03, 2014 5:31 pm
what are the dimensions?
zeusrotty
Post  Jasonscottw on Mon Mar 03, 2014 5:48 pm
Not positive yet. I believe the diameter of the booster is 7", and with MC it protrudes 9" from the firewall.
Those are just guestimates based on pics.
I cannot find a diagram.
A hot rod buddy of mine who uses them all the time says the diameter is only 5",
but I'm skeptical.
I'm on the hunt for real measurements.
Jasonscottw
Jasonscottw
Post  zeusrotty on Mon Mar 03, 2014 6:16 pm
It would be good to know how wide it is. I will take some measurements when I get home.
zeusrotty
Post  944convert on Mon Mar 03, 2014 6:36 pm
It would be great news if the driver's side LS head cleared this booster...that space is really tight...please let us know.
Post  Jasonscottw on Mon Mar 03, 2014 7:14 pm
Will do.
Booster is definitely 7" diameter, about 2" thick. Also used on Suzuki Swifts. Do not know length of whole unit with MC yet.
Two front brake lines, one rear.
I guess the question now is whether a 7" x 2" booster "bowl" will even fit-
Jasonscottw
Jasonscottw
mustang hb alternate??
Post  Gutterboy on Mon Mar 03, 2014 10:21 pm
i find this post very intriguing; can't wait to see if some others can verify a test fit or swap some dimension data here. fingers crossed on a home run here but any brake expertise that can weigh in on what this geo metro or suzuki swift presents for bore and stroke of master cylinder compared to what is desired and such? or am i still stuck in manual brakes land here as well as the clutch threads i have read tonnes on.
forgive me in advance.
Gutterboy
Post  Jasonscottw on Mon Mar 03, 2014 11:23 pm
Geo metro bore is 13/16, haven't figured out what the stroke is yet-
Jasonscottw
Jasonscottw
Post  944-LT1 on Tue Mar 04, 2014 9:29 am
Ive never liked being the one that says something wont work but Ill post this picture of the area that it would have to be and let you all decide. I hope Im wrong cause I would love to have a vacuum booster in the car.
Post  Jasonscottw on Tue Mar 04, 2014 11:00 am
Whoa . . . That is snug. Didn't realize it was that tight. Doesn't seem like there is a chance of anything fitting.
I picked up a booster for $15 so might still take a stab at it when I get the engine in.
Maybe I could recess/french the booster into the firewall.
What about a remote booster?
Thanks 944-LT1 for the pic, exactly what I was trying to find out-
Jasonscottw
Jasonscottw
Post  money pit 951 on Tue Mar 04, 2014 2:16 pm
I'm running a remote vacuum booster. The initial boost isn't nearly as smooth and takes a little getting used to, but they work fine and certainly give a boost. You have to find a place to mount them as they're quite large. My car is a track car so many street going parts are removed freeing up space
money pit 951
money pit 951
Post  zeusrotty on Tue Mar 04, 2014 5:28 pm
can you show pics of it? Or part #'s?
zeusrotty
Post  Jasonscottw on Tue Mar 04, 2014 5:50 pm
Maybe this should be in a new or existing thread,
but what about the hanging/swing wilwood pedal assembly w/dual MC?
In searches I've found info on the bottom mount assemblies, which seem like a headache because of seat issues and steering wheel extensions, but nothing about the hanging systems-
My firewall mounted Wilwood clutch master cylinder is set up and functioning well, so I'm only considering the brake pedal assembly.
Also, Power Brake Service has some pretty amazing hydroboost systems and
explanations of why the electric boosters aren't so great.
Anyone specifically used their Hydroboost set ups?
Manual dual wilwood? Hanging assembly? Remote booster? Hydroboost? I know the specifics of most of these have been covered in the forum, but am I missing any other options? Has anyone tried mounting a mini booster behind the firewall?
Jasonscottw
Jasonscottw
Post  zeusrotty on Tue Mar 04, 2014 5:52 pm
Thats all been talked about.  We were just looking for something boosted that is smaller than the hydroboost unit. And not the manual wildwood stuff. The electric boosted stuff sucks terribly.
zeusrotty
Post  944convert on Wed Mar 05, 2014 12:46 pm
Jasonscottw wrote:Booster is definitely 7" diameter, about 2" thick.
Too bad...about 4.75" diameter would be cutting very close.
Post  Jasonscottw on Wed Mar 05, 2014 2:22 pm
What about the geo master mounted onto one of the right angle booster brackets?
It might fit over the clutch master if the cluster of wiring was moved a bit.
Like this:
http://www.kugelkomponents.com
Jasonscottw
Jasonscottw
