» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
What engine to choose...
Post  ThomasJoseph315 on Fri Feb 28, 2014 8:01 pm
Greetings everyone!
 So i got an original 924,.. so original the vin is 3963 in production out of 150,000  Shocked She's been a beauty to drive over the past year, but I am considering dropping in another engine. what engine I have no idea. I know a V8 might be to powerful for the 924 torque tube and transmission etc. I have no ambitions of huge horse power here, but I simply want an engine that I can readily get parts for.
What engine is the easiest most cost effective engine to put in this car?
ThomasJoseph315
Re: What engine to choose...
Post  87-944S on Fri Feb 28, 2014 11:07 pm
I think all the LS series except the ones with a dry sump oiling system are equal in installation effort. Any of these engines in stock trim will keep a smile on your face! There are some V6 options out there, but, why would you settle for a V6 when you can have a V8!
Post  ThomasJoseph315 on Sat Mar 01, 2014 1:44 am
87-944S wrote:I think all the LS series except the ones with a dry sump oiling system are equal in installation effort. Any of these engines in stock trim will keep a smile on your face! There are some V6 options out there, but, why would you settle for a V6 when you can have a V8!
if I had a 944 or a 924 turbo to hold up against the torque I would be happy to do it.
ThomasJoseph315
Post  HorizonblueDK on Mon Mar 03, 2014 12:46 am
I don't think there is an easy engine swap for the 924(or 944)....
I believe that any V engine swap requires the removal of the brake booster. The cross member will probably also collide with the oil pan of any engine you choose. If you don't find an engine within the Audi/VW family with the 016 boltpattern, you will have to make an adaptor and the list of jobs to do goes on.
But if you could find an Audi 5 cyl engine with cross flow head, the swap would be just a bit easier than other swaps, I think. The old bell housing can be used and there is room for the brake booster.
I have a straight six VW engine in my 924. I will not say that it was straight forward to do that swap, but it was probably a lot easier than a V-something swap.
HorizonblueDK
Post  ThomasJoseph315 on Mon Mar 03, 2014 3:02 am
HorizonblueDK wrote:I don't think there is an easy engine swap for the 924(or 944)
Is there an Engine code for that?
ThomasJoseph315
Post  HorizonblueDK on Mon Mar 03, 2014 4:47 am
I'm not sure, but some older 4-5 cyl engines (mid 1990s and back) has this boltpattern. Pay attention to which direction the starter protrudes. The VR6 engine has a different pattern, unfortuneatly. Would be a nice swap. No one has apparently finished such a swap. There are a few dead forumthreads where a VR6 build has been started, but never finished.
HorizonblueDK
Post  HorizonblueDK on Tue Mar 04, 2014 3:09 am
The VR6, as well as a few other VW engines has the starter mounted in the bell housing. This means that the starter is pointing towards the rear of the car, when mounted longitudinal. Something like the 944. It may be possible to redo a 944 bell housing for a VR6 or any other engine, with the starter in the bell housing, but that probably takes the word "easy" out of a swap. The original VR6 bell housing can be bolted onto the transaxle (as seen on one of the dead forum threads), but it requires cutting in the firewall, to give space for the starter.
HorizonblueDK
