» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
FS 5.3 LM7 944
FS 5.3 LM7 944
Post  watsondk on Fri Feb 21, 2014 3:11 pm
I hate to do this, but my 948 is up for grabs, decided I want my PhD...
Here is my craigslist ad with pictures:
Additional info for my fellow 944hybrids members:
Many of you know my car as xschops that his build thread details. You can read what originally went into the vehicle here:
It has been my daily driver for the past year. All told I have somewhere around 6-7k miles since I’ve purchased. Odometer was not functional when purchased, I have since replaced the odometer gears.
I have made many upgrades and minor changes since I purchased (somewhat in order):
New hood pin supports, realigned hood, and replaced windshield which the hood cracked before realigning.
Removed spare tire well which had been partially cut open and replaced with new sheet steel floor pan, added soundproofing material
Swapped seats to lighter weight Corbeau seats that are race harness compatible
New exhaust gaskets at header and collectors, fixing small exhaust leaks, also added a tip to the exhaust to prevent exhaust buildup inside rear bumper
Swapped the LS430 front brake kit to 951 fronts to allow for 16 and 17” wheels-with new master cylinder braking power is within 5% of LS430 setup
New ¾” bore master cylinder to better balance brake bias w/dual MC setup
Full suspension swap:
Front-Yellow Konis with coilover kit, 450 lb/in springs with helper springs, turbo front swaybar, xschops RX7 control arms and bump steer kit, 951 calipers/rotors
Rear-30 mm torsion bars, yellow konis, turbo sway bar, RX7 calipers 951 rotors
Added back seat panel to cover exposed sheet metal and reduce road noise
Replaced torque tube with stock 87 unit
Replaced steering wheel and hub with a Grant wheel-much better than the momo knockoff
Resealed and added spoiler to rear hatch, surprising how much quieter highway driving is
Replaced xschops short-throw shifter kit with OEM, kit had worn and was vibrating/rattling
Replaced door handles with OEM Porsche script handles
Replaced Fuse Block due to faulty internal connections
The bad:
Dash is cracked
Could use new sunroof and door seals
Has a few minor dents one slightly worse on passenger rear fender, paint cracking along fiberglass rear bumper-all from before my purchase-to look 100% would need stripped and re-sprayed.
Radiator recently developed a slow leak when cold, if I find a local replacement I will replace in the coming weeks.  Currently has 944 NA radiator.
PM for more details, I'm located in Detroit Metro
watsondk
Re: FS 5.3 LM7 944
Post  Lemming on Fri Feb 21, 2014 4:02 pm
GLWS and PhD  Very Happy
Signed
Professor Tim
Re: FS 5.3 LM7 944
Post  watsondk on Sun May 25, 2014 9:04 pm
Thanks Lemming, my job is paying for PhD which is great but means it will be part time and take a while.
Bumping for price drop, new craigslist add at the following link.
I replaced the leaking radiator mentioned in the original post, car is running great and ready for the summer.
watsondk
Re: FS 5.3 LM7 944
Post  mc05duck on Sat Jun 14, 2014 2:59 pm
What is the difference between and LM7 and a LS1 or LS2?  Are the weights comparable or is the LM7 about 80lbs. heavier like the LT V8's?
Great looking car too btw... Tempting...
PS - How did you remove your rear windshield wiper and what kind of metal plug did you use to fill the hole?
Thanks!!!
mc05duck
Re: FS 5.3 LM7 944
Post  watsondk on Sat Jun 14, 2014 3:08 pm
The lm7 is an iron block with aluminum heads while the ls1 is all aluminum. Not sure of the exact weight difference but it is heavier. Same mounting points though.
The rear wiper hole is essentially a ruber gasket on each side of the glass squeezed together by aluminum disks. It is watertight and has never given me any problems. When driving the rear glass stays fairly clear.
watsondk
Re: FS 5.3 LM7 944
Post  xschop on Thu Jul 03, 2014 3:58 pm
I just read your thread. I'm thinking I may have thrown the schnell shifter back on when I installed your new clutch. I was using Mike's shop/lift and we had 3-4 944's under construction at the time. Got a pic of it? I made few this past weekend with lighter alloy arm and I don't see how they could wear out for eons because of the Teflon-lined spherical bearing. Let me know. If it doesn't look like this, I'll send you one FOC.
Teflon heim joint.....
Re: FS 5.3 LM7 944
Post  Outofhand on Tue Jul 08, 2014 2:47 pm
If I didn't just buy a brand new car I'd be all over this. Sad
If it doesn't sell by Christmas I'm on my way.
Outofhand
Re: FS 5.3 LM7 944
Post  watsondk on Tue Jul 08, 2014 5:04 pm
Thanks xschop, I'll send you a pm with picture when I get a chance this weekend, was definitely a different style shifter on there.
Outofhand, I've had three separate "sure" buyers lined up who fell through at the last minute so who knows, maybe I need to ask for a deposit when they commit to buying and I pull it off craigslist???
Cheers!
watsondk
Re: FS 5.3 LM7 944
Post  xschop on Tue Jul 08, 2014 6:52 pm
May be couple weeks because I plan to do a large run of them again.
So whoever buys the car I will send directly to.
There is a lot of custom stuff on this car. With hydroboost setup, the brakes would be a whole new ballgame and a lot has been done in that arena since I built the car.
Re: FS 5.3 LM7 944
Post  Dredep on Mon Jul 21, 2014 11:17 am
Hi. Is the car still for sale? Can you pm your email and asking price? Thanks
Dredep
Re: FS 5.3 LM7 944
Post  watsondk on Sat Apr 11, 2015 3:59 pm
Hey all, I ended up keeping the car through the summer and stored during the winter. I just posted the car back up for sale locally. Giving everyone here a chance as well, price reduced!
Asking $8,000 firm.
watsondk
Re: FS 5.3 LM7 944
