Intermittent problem with heater valve
Ran into a problem yesterday with my heater function. I was driving to work and came up on a traffic jam. After a couple minutes of 5mph creeping my heater started blowing cold and the temp gauge started to creep up 1 mark above normal. When the traffic let up and I got back to speed the temps came down and eventually the heater started blowing hot again. Coolant level looks normal and I don't see any signs of leaks. Is this a sign of a bad thermostat?
948inVA- Posts : 224
Re: Intermittent problem with heater valve
Sounds like the thermostat.
