» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
Just out of curiosity...
Post  HorizonblueDK on Mon Jan 20, 2014 7:55 am
Is it possible to install an LS1 engine into a 944, not changing anything about the cross member, instead build a low custom oil pan, and in the end, be able to close the hood?
I read somwhere on this site, that in order to close the hood, the engine and cross member must be lowered. Is that really true? What is stopping the hood from being closed?
I have a straight six in my 924, in the original engine height. I think I have a little under 1 inch clearance = plenty Very Happy
HorizonblueDK
Re: Just out of curiosity...
Post  Admin on Mon Jan 20, 2014 8:02 am
Shocked
READ!
 Shocked
The motor ( throttle body to be exact) is what keeps the hood from closing! Laughing Laughing Laughing Laughing
Post  HorizonblueDK on Tue Jan 21, 2014 4:49 am
I see.
So if one took the time to build a new intake manifold, it was possible to install the engine in the original height and leave the front suspension unchanged.....
But off course, the cathedral ports on the LS1 are quite difficult to fabricate, so the solution could be to find a carb intake manifold(aluminium) and modify that one.
HorizonblueDK
Post  skywalker01 on Tue Jan 21, 2014 6:13 am
Or you could modify the hood to provide the additional clearance you need.
skywalker01
Post  Luke714 on Tue Jan 21, 2014 10:43 am
I thought I remember lots of people not needing to space the crossmember down the 1/2", or at least keeping the spacers to 1/4" instead.
Luke714
Post  zeusrotty on Tue Jan 21, 2014 7:55 pm
I just added a hood vent. No spacers here.
zeusrotty
add on question
Post  Gutterboy on Tue Jan 21, 2014 9:33 pm
so if went the body work route for the hood which let me avoid the spacers does this mean i wouldn't have to mess with extending the steering shaft by the extra x amount with some borgesen joint or whatever that i was reading?
if this is true sounds like the bodywork on the hood with adding a nice little reverse muscle vent could help with airflow as well as save some other fabrication that i would be less capable at.
Gutterboy
Post  Rich L. on Tue Jan 21, 2014 11:14 pm
The brake master also gets harder to fit if you don't use spacers.
Post  Lemming on Tue Jan 21, 2014 11:21 pm
zeusrotty wrote:I just added a hood vent. No spacers here.
Same here, hood vent, no spacers.
Post  948inVA on Wed Jan 22, 2014 5:28 pm
I'm running mine with no spacers and stock hood.. manual steering and hydroboost. You need to trim the hood brace and grind some material off of the throttle body. The steering shaft does not need to be changed.
948inVA
clarification
Post  Gutterboy on Wed Jan 22, 2014 6:59 pm
supes6 wrote:The steering shaft does not need to be changed.
even if i am running a power steering setup with the ls1 factory pump connected i wouldn't have to extend the shaft if i used no spacers right?
it's when you use the spacers that you have to extend the shaft if i understand correctly?
also, as per your footnote details on your '86 951, since you have hood pins did you end up deleting the hood latch to also make room for the throttle body with not using spacers on the block?
Last edited by Gutterboy on Wed Jan 22, 2014 7:01 pm; edited 1 time in total (Reason for editing : saw the footnote on your signature on your car mods)
Gutterboy
Post  docwyte on Wed Jan 22, 2014 10:24 pm
No hood latch. It also depends on your throttle body. I'm running a FAST92 throttle body and I had to trim away the hood to get it to fit *with* spacers.
The headers are also designed to work with spacers, so they may not fit without them.
Post  HorizonblueDK on Thu Jan 23, 2014 2:44 pm
When I did my straight six swap(in my 924), I was very anxious to find out if it could be done without dropping the crossmember and/or adding a bump in the hood. Fortunately it could. I would just like to change as little as possible to the car. Because it's an inline engine, I can even keep the original brake booster.
If I was going to do a 944-LS1 swap, I would also try to fit the engine, with original hood and no changes to the crossmember. Well obviously an LS1 would not fit without replacing the brake booster with hydro boost. And I have doubts that I can pass MOT, where I live, without the original booster. Maybe the car will have to be tested and certified by some kind of institute.
HorizonblueDK
Post  Admin on Thu Jan 23, 2014 5:07 pm
I have done a couple without spacers by moving the TB to a different location.
That was on a Lemons race car so it may not be for everybody......
Post  acorad on Thu Jan 23, 2014 5:17 pm
Admin wrote:That was on a Lemons race car so it may not be for everybody......
Genius. But I'm glad it's not in my region...
Post  Admin on Thu Jan 23, 2014 7:24 pm
What? you don't want to race a LS1 powered Lemons car? Laughing Laughing Laughing Laughing
Post  gamman on Tue Feb 04, 2014 9:03 pm
Everyone wants to!,
gamman
