» What is VSS?
Today at 10:53 am by C4924S
» The famous Hydroboost issues....
Today at 10:43 am by Hotrodz of Dallas
» RHD Conversion Issues...
Yesterday at 4:24 pm by UK952
» Considering doing LS1 Swap
Sat Apr 21, 2018 10:29 pm by hooplajr5
» WTB: 944 Turbo Roller
Sat Apr 21, 2018 8:31 am by Maxx
» Blue Alternator Wire
Fri Apr 20, 2018 11:22 pm by Porsche951toLS3
Thu Apr 19, 2018 4:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Thu Apr 19, 2018 6:16 am by bikerdude
Thu Apr 19, 2018 2:33 am by Flashy2003
» ecotec swap
Thu Apr 19, 2018 12:13 am by sharkey
April 2018
30
G31 Transaxle
G31 Transaxle
Post  Red944ls1 on Fri Jan 17, 2014 10:34 pm
I was looking at the 5th gear ratio of the G31 Transaxle and it looks to be .60. Does anyone know if the 5th gear is interchangeable with the 86 951 Transmission 5th gear. I have read where it was interchangeable with some Audi gear sets. I am thinking this would give an even better cruising RPM.
I have a 1980 924 Turbo (931) with the snail shell transaxle that I am not using so I figure it would be a nice upgrade.
Thoughts.
Red944ls1
Re: G31 Transaxle
Post  944-LT1 on Fri Jan 17, 2014 11:31 pm
Re: G31 Transaxle
Post  948 on Sat Jan 18, 2014 10:20 am
I don't believe those gears will fit in the 083 style boxes.
You can use an NA 944 0.73 5th gear Vs the 0.83 already in the Turbo box to reduce rpms. IIRC there are some European Audi boxes which use a 0.64 5th, they are very rare; I don't know if anyone has tried installing one in a 944 box...
Try using the advanced search function above, there has been a lot of talk about this over the years...
http://944hybrids.forumotion.com/t1190-5th-gear-options-audi
G31 transaxle. (taller fifth)
Post  chasse1118 on Sat Jan 18, 2014 10:22 pm
All the talk of using early n/a fifth gear or early 80's audi 5000 diesel fifth, Did anyone every research getting a custom fifth gear ratio cut by an outside source? Albins in Australia, California motor sports, Mike Monson at Guard transmission??
chasse1118
Re: G31 Transaxle
Post  v8carreragts on Tue Feb 04, 2014 1:08 pm
The G31 gears will not fit. They are completely different.
As for the Euro 0.63, if you can find one it should fit as long as it is from an 016.
Albins only makes shorter 5th gears 1.0 and 0.96. (sold by California Motorsports) --and very expensive.
The most reasonable choice is the 0.73.
Re: G31 Transaxle
