Help with strange front end vibration please.
I have a strange INTERMITTANT vibration coming from the front end. It usually starts after a run at 60/70 mph and can be felt through the steering wheel. It feels like an out of balance or loose wheel. After stopping and restarting the problem goes away.
This has occurred on and off since the original LS1 conversion. Car is a 88 NA.
During the conversion I did the following:
Rebuilt front struts with Koni cartridges, lowered springs.
Lexus LS430 Calipers with xschops adapters, Boxster S Rotors
Replica Cup one wheels and new tires. New Tie rod ends.
I rebuilt the lower A arms with new ball joints. All new bushings.
New wheel bearings.
Willwood tandem master cylinder.
Turn one PS pump.
Wheel alignment performed.
Since the conversion have done the following:
Changed the lower A arms to steel arms, new bushings and outer ball joints.
Porsche cup two wheels and new tires. Wheel bearing's checked.
Hydraboost brake system.
Could this problem possibly be caused by the steering rack or the upper strut mounts?
Original car had 150,000 miles.
Any ideas or suggestions would be welcomed, this is spoiling a very special car.
Thanks, Mike
New wheel bearings.
Turn one PS pump.
Thanks, Mike
Last edited by simon123 on Sun Jan 05, 2014 8:59 am; edited 1 time in total (Reason for editing : Added mileage)
simon123- Posts : 125
Inner Tie rods.
After a discussion with xschop it's possible that my problem may be the inner tie rod ball joints in the rack, probably worn. I have never changed these inners, only the outer ball joints at the hub.
Guess the next job is to try this before spending a bunch of money on a re-built rack.
Anybody have interesting stories about inner tie rods???
Re: Help with strange front end vibration please.
Also an improperly adjusted wheel bearing spindle nut can cause an erratic vibe as well.
At 150k I'd suggest replacing all the wear items in the front end.
acorad- Posts : 697
Tie rods
I have changed the inner tie rods at the rack and so far have not had the front end vibration.
When you had the alignment done , did they go by the tech bulletin from Porsche for the 944 and it's front end issues. I'm not a hundred percent sure but I think it was discussed here or on Rennlist. Very common problem....
Alignment
Last alignment done before I changed the inner tie rods was set to the data generated by the database in the alignment computer. I have not done an alignment check yet, I noted the position of the rods in the xschop bump steer blocks and carefully re-set them. Need to get an alignment check done.
I cannot find an official Porsche publication (tech bulletin) that states the toe-in as degrees and minutes.
Do a search on Rennlist. I know it's there somewhere. Basically says that the toe in needs to be a degree or two more than modern computers say.
