» 5.3 conversion on 88 Turbo
Today at 1:23 pm by dabrough
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
» Engine Accesory Kit and Turbo Manifold Fitment
Wed May 09, 2018 10:02 am by Jchard944
Tue May 08, 2018 6:22 am by matt889
May 2018
78910111213
14151617181920
21222324252627
28293031
Anyone have their Boxster ABS pump in and wired?
Page 3 of 3 Previous  1, 2, 3
Re: Anyone have their Boxster ABS pump in and wired?
Post  Rich L. on Sat Mar 21, 2015 12:47 pm
I don't know, Doc. I found the wire under the dash, where I connected it to the ABS. And I found it outside the firewall, where I connected it to the alternator. I think it goes into the dash and connects through the battery light, the bulb giving it some amount of resistance. The ABS watches it to know when the engine is actually running and not just the ignition is on.
Post  docwyte on Sat Mar 21, 2015 1:54 pm
Hmm. Ok, guess I'll give it switched 12v from the alternator then and see what happens. Unless there's a signal wire off the alternator?
Post  docwyte on Fri Aug 07, 2015 1:17 pm
To close the loop here, I was finally able to get this working. Several things had to get wired on my car, one was the alternator charge wire, the other was properly bypassing the alarm ECU (which was a PITA to figure out since my car is an '89) and finally was giving the ABS 12v.
It now works! That's the good part. The bad part is since I'm running a hydroboost brake setup you have to be really careful with modulation. If you hammer on the brakes, you can get the ABS to go into Ice Mode" and nothing happens. You literally just don't stop period. You have to ease off the brakes, then back onto them again. Very freaky when it happens on track, let me tell you...
