» 5.3 conversion on 88 Turbo
Today at 1:23 pm by dabrough
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
» Engine Accesory Kit and Turbo Manifold Fitment
Wed May 09, 2018 10:02 am by Jchard944
Tue May 08, 2018 6:22 am by matt889
May 2018
78910111213
14151617181920
21222324252627
28293031
Anyone have their Boxster ABS pump in and wired?
Page 2 of 3 Previous  1, 2, 3  Next
brakes
Post  kevin924kevin on Wed Apr 02, 2014 9:37 am
Hello, is there any updates for the abs, are any of you running hydroboost with the abs?
Re: Anyone have their Boxster ABS pump in and wired?
Post  docwyte on Wed Apr 02, 2014 10:00 am
I'm running hydroboost, my pump is going in now. Track day April 26th. I'll let ya know what I think...
brakes
Post  kevin924kevin on Wed Apr 02, 2014 11:23 am
Thanks Doc, looking forward to your results.
Post  docwyte on Wed Apr 02, 2014 11:26 am
Yeah, me too! The stock ABS system sucks, it doesn't help stop the car better, it's barely adequate at keeping the tires from flat spotting. I'm hoping this more modern system actually gives me the confidence to hammer the pedal and let it work everything out...
Post  Lemming on Wed Apr 02, 2014 12:17 pm
Just remember that threshold braking is much more efficient than ABS or cadence braking.
Post  docwyte on Wed Apr 02, 2014 12:28 pm
True, but having the confidence that you're not going to lock up helps alot...
Post  87-944S on Wed Apr 02, 2014 11:42 pm
And for those of us that drive on the street as well, very cheap effective insurance!
Post  docwyte on Fri Apr 04, 2014 4:33 pm
What are people doing for bleeding their brakes/ABS pump once in? Is there a way to manually force the pump to cycle? Either with a OBD2 tool or by jumping one of the wires?
Post  docwyte on Fri Apr 11, 2014 11:55 am
So the pump is in and wired. However the plug I got from Oklahoma Foreign didn't have a pin out for the ABS light on the dash? Anyone else run into that? Right now I'm just going to go without the warning light...
Post  docwyte on Thu Apr 24, 2014 1:43 pm
Having some issues with this. The pump is continually cycling on/off. My shop seems to think it's because the pump I have is a CAN-BUS pump. I got a pump ending in "00" with the two row plug, isn't that the right one?
Do I have it wired wrong? How/what do I do to solve this?
Post  Rich L. on Thu Apr 24, 2014 5:25 pm
Mine is 996.355.755.04. CAN bus didn't come in until PSM.
Post  docwyte on Thu Apr 24, 2014 5:46 pm
Hmmm, so apparently the plug I got from Oklahoma foreign was different . It didn't have a pin for the alternator trigger or the abs dash light. So neither were hooked up, pins 10 and 21. Think that's the issue?
Post  docwyte on Wed Sep 24, 2014 5:52 pm
Ok, still having issues with this. Got the right plug from Oklahoma Foreign and have it wired in. Getting the "antilock" light on my cluster to light up now. (After replacing a ton of cluster bulbs some previous douchebag owner removed)
Now the "antilock" warning light isn't going out and the ABS brakes aren't working. WTF!
My suspicion is the antilock brakes on the car never worked and the previous owner pulled the bulb to hide the fact they were broken.
Where do I start with trouble shooting this?
Post  944convert on Thu Sep 25, 2014 1:28 pm
docwyte wrote:Where do I start with trouble shooting this?
Rennlist Boxster ABS Help:
https://www.google.com/?gws_rd=ssl#q=ABS+site%3Ahttp%3A%2F%2Frennlist.com%2Fforums%2Fboxster-and-boxster-s-986-forum
Rennlist Turbo ABS Help:
https://www.google.com/?gws_rd=ssl#q=turbo+ABS+site:http:%2F%2Frennlist.com%2Fforums%2F944-turbo-and-turbo-s-forum
Rennlist ABS Help:
https://www.google.com/?gws_rd=ssl#q=ABS+site:http:%2F%2Frennlist.com%2Fforums%2F924-931-944-951-968-forum%2F
Pelican Boxster ABS Help:
https://www.google.com/?gws_rd=ssl#q=ABS+site%3Ahttp%3A%2F%2Fforums.pelicanparts.com%2Fboxster-cayman-forum%2F
Pelican Turbo ABS Help:
https://www.google.com/?gws_rd=ssl#q=ABS+site%3Ahttp%3A%2F%2Fforums.pelicanparts.com%2Fporsche-944-turbo-turbo-s%2F
Pelican ABS Help:
https://www.google.com/?gws_rd=ssl#q=ABS+site%3Ahttp%3A%2F%2Fforums.pelicanparts.com%2Fporsche-924-944-968-technical-forum%2F
Post  Lemming on Thu Sep 25, 2014 1:31 pm
Have you, or anyone else for that matter, been able to read any OBDII codes from the ABS?
Post  docwyte on Thu Sep 25, 2014 6:35 pm
Nope, they don't seem to communicate with one another. (The ABS and the Camaro PCM)
Post  Lemming on Thu Sep 25, 2014 6:38 pm
One wire from the ABS goes directly to the OBDII port, I assumed that you could read codes from that?
Post  docwyte on Thu Sep 25, 2014 6:48 pm
We have that hooked up, but I don't think it's sending any data that HP Tuners can decipher.
Post  Rich L. on Thu Sep 25, 2014 10:42 pm
I hooked that wire into a port but neither my Audi nor generic code readers can communicate with the abs computer. I believe it takes the Porsche specific software and that's prohibitively expensive.
Post  Lemming on Fri Sep 26, 2014 7:01 am
Rich L. wrote: I believe it takes the Porsche specific software and that's prohibitively expensive.
I'll try to find out on Sunday, we have a DE planning meeting and one of the members has an independent Porsche shop.
Post  Lemming on Fri Sep 26, 2014 10:52 am
Lifted from a Pelican thread
"No, Porsche does not require a special code reader to access OBD II codes, just about any make or model will get you into the “non proprietary” codes section in the DME, as required by Federal regulations. Unfortunately, to get at what Porsche has designated as “proprietary” (ABS, PSM, Airbags, etc.)you will need a PST II, PIWIS or Durametric system."
http://www.durametric.com/buyus.aspx
Post  Rich L. on Fri Sep 26, 2014 11:24 am
The same kind of kit for VW/Audi was 99 bucks.
Post  Lemming on Fri Sep 26, 2014 12:02 pm
Rich L. wrote:The same kind of kit for VW/Audi was 99 bucks.
Porsche tax!
Post  docwyte on Fri Oct 10, 2014 5:05 pm
What's the specific part # of the boxster ABS pump that you guys have in and working in your cars?  I'm beginning to think I have one for a traction control car, that's why it's not working...
Went through the thread, is everyone using the part # Rich posted? 996.355.755.04? They're cheap enough, $50 shipped from eBay vendors...
Post  docwyte on Sat Mar 21, 2015 8:48 am
Thanks to Rich's help I've found the wire I need to tap to give an alternator signal. Unfortunately my alternator has a different plug so I can't use that painless plug that I bought, that Rich is using.
So, for the red wire with black stripe, do I need to give it a constant 12V signal from the alternator, or a switched 12V signal from the alternator?
TIA!
