» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
Hydraulic brake setups
Post  whty8911 on Wed Dec 25, 2013 4:23 pm
For those of you who track you car, what type of hydraulics are you using? Do they provide sufficient stop power? Any fade? Any failed setups that you have tried in the past?
I am trying to get my car finished for next season and currently have a manual brake setup from RH. As far as street driving the setup appears to be sufficient but am worried that it will not hold up at the track. Not so worried about the calipers/ rotors/ pads. More worried about master cylinder / bias issues? Also if the master cylinder will provide enough pressure for high speed stops with being accompanied by an assist.
whty8911
Re: Hydraulic brake setups
Post  whty8911 on Wed Dec 25, 2013 4:24 pm
Just a little info on the setup. Its a 1987 porsche 944 turbo with rebuild factory calipers. New proportioning valve, new lines, rebuilt calipers, new performance rotors, hawk pads, etc. Master cylinder is from RH and came with the kit.
whty8911
Hydraulics
Post  simon123 on Wed Dec 25, 2013 5:04 pm
I started with a tandem Willwood as specified in Sloan's book. Brakes were poor/heavy and needed quite a pedal push. I switched to a Mustang hydraboost/prop valve and now they are awesome. I have Boxster S Front rotors with LS 430 Calipers and 951 rear rotors and RX7 Calipers.
Not sure if the racer groups allow this
simon123
Post  Lemming on Wed Dec 25, 2013 5:33 pm
Check out a few threads in the brake section. I am happy with my DMC setup, but have had to upgrade my brakes and rotors for racing. I was using turbo s calipers on the front and turbo rears (with Hawk DTC 70/60's). Fronts are now 330mm cayenne rotors and wilwood 6r calipers. Rears are the same.
Post  whty8911 on Wed Dec 25, 2013 8:31 pm
Lemming, who sells the dmc system you are using? I was thinking about a floor pedal assembly. Any experience with them?
whty8911
Post  Lemming on Wed Dec 25, 2013 10:19 pm
whty8911 wrote:Lemming, who sells the dmc system you are using? I was thinking about a floor pedal assembly. Any experience with them?
Mine was made locally. The pedal systems are great, but the floor mount system will push you see back 3 inches. That put my head under the rollbar and I was not interested in being in that position. Measure carefully.
Post  whty8911 on Wed Dec 25, 2013 11:28 pm
Right now my car is an empty shell and even for a big guy (6'1 240lbs) I sit close when I drive. So moving the seat back would not be an issue. I'm thinking a pedal system is my best option so far. Ideal pressure, stress removed from firewall, more room in engine bay, etc. I still have some time before that is a problem to address. Thanks for the input.
whty8911
Post  Lemming on Thu Dec 26, 2013 6:47 am
Check out "Rich's LS powered 944 track car" thread in the member conversion area. Rich did a nice job of mounting a tilton floor pedal set.
Post  Rich L. on Thu Dec 26, 2013 11:35 am
I made a floor plate from 3/8" aluminum and mounted a Tilton pedal box. Works great for me at 5'7", but I'm only 3 clicks forward on the seat rails from the back. Before the pedals I felt uncomfortably close to the dash and wheel.
http://944hybrids.forumotion.com/t1386p15-rich-s-ls-powered-944-track-car#17709
The mechanical balance bar works well for bias, brakes feel great. But the clutch is very heavy due to needing a 1" compact master to get clutch release.
Good luck with your build.
Post  Lemming on Thu Dec 26, 2013 7:12 pm
whty - make sure you check out the pics of Rich's vs. my rollbar. Mine is directly in line with the b-pillar and Rich's is behind. I'm 5'7" and the floor mounted system would not work for me.
