Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
+8
laptop_geek
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Here's the v6 cougar fans on the rad. The fans fit perfectly on the Summit radiator #SUM-380645. The hoses might be a tight squeeze though. We'll see what happens when I go to put the hoses on. There's about an 1/8" between the outlet and the fan housing. The mustang guys say they flow 3400cfm.
Re: Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
What are the depth of those fans?
I dremeled the area around the top inlet hose on the NA fans even and the fan bridge to get more hose clearance. Also are you going to reweld the inlet or remove the hood latch arch? Or tilt forward?
Looks good! Let's see how well it fits in the car though...
I haven't looked at how I'm going to mount it yet. Do you have any suggestions? What rad are you using?
The only reason I chose this one is because the manual says it requires minimal modifications to the stock support braces.
Here's a 2d cad drawing of the fans.
Fans
What is at the 7 o'clock position on the left hand fan?
How does the size of that radiator compair to the stock 951 radiator?
laptop_geek- Posts : 230
951------19.75" x 14" = 276.5 in sq overall size 23.75" x 14"
380645---20.75" x 15" = 332 in sq overall size 23.875" x 16"
1/8" wider and 2" taller.
v8carreragts- Posts : 332
V6 Fans
Can someone tell me what is at 7 o'clock on the edge by the left fan.
I have a Griffin rad and that's where a pipe exits the tank. Can I remove material from the shroud
in that area?
in that area?
I can tell you in the spring although, Im sure that doesnt help you now. Sorry, my car is covered under 8" of snow right now and all wrapped up in a tarp. But from the picutres it looks like it would fit. You'd have to cut out that temperture sensor thing though.
fliermike45 wrote:Can someone tell me what is at 7 o'clock on the edge by the left fan.
could it be the Auxiliary Fan Control Unit ?
944convert- Posts : 253
Its a resistor
The part in question is the Cooling Fan Dropping Resistor for the factory low speed fan controller. It is a 0.4 ohm solid wire resistor that heats up as power is applied to the fans. It is placed in the air stream of the fans simply to cool itself off so it doesn’t burn up.
V6 Fans.
Great info thanks, I won't need the dropper as I plan to wire the fans to ECU and use series'parallel relays to get the low and high speed.
Seems this fan unit is a good price and sized right for the radiators specified in Sloan's manual.
Spence, how did you end up attaching the fan to the radiator?
zeusrotty- Posts : 444
I made some brackets (top and bottom) that hold both the rad and the fan together.
You mount these yet? How are they working? I'm debating replacing my current Spal electric fan with these...
I used those fans on the 928 LS1 swap....2 thumbs up...flow like crazy
docwyte wrote:You mount these yet? How are they working? I'm debating replacing my current Spal electric fan with these...
Yep, I've had them running for a year... I'm running them from the ECU with the 3 relay setup.
Any clearance issues? Where'd you get em?
I went to the junkyard for mine. The fan fits tightly in the old opening. I cut the old brackets along the side of the car off.
I got mine from ebay. they aren't in yet though. Hopefully it will all be done next week.
Having issues getting these fans to fit. I have the RH/RD radiator and these fans appear to be too deep to fit without hitting my water pump pulley, etc, etc.
How are you guys getting these to fit?
I went and bought them and didn't get them to fit either. I ended up with 2 11 or 12 inch very high cfm be cool fans that work really well.
Hmm. Anyone want a brand new set of Cougar fans? $68 shipped!
cougar fans
[quote="spence"]Here's the v6 cougar fans on the rad. The fans fit perfectly on the Summit radiator #SUM-380645. The hoses might be a tight squeeze though. We'll see what happens when I go to put the hoses on. There's about an 1/8" between the outlet and the fan housing. The mustang guys say they flow 3400cfm.
Hey Spence,
What year of cougar (v-6) did the fans come off of? I am just getting to this part of my build and was concerned about cooling.
Thanks for the info,
George
Hey Spence,
George
Tehone- Posts : 84
95-2000 v6 mercury cougar / mystique or ford contour.
Page 1 of 2 • 1, 2
Page 1 of 2
