» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
GM's new V6 is finally out.
Post  xschop on Tue Nov 26, 2013 10:35 pm
LV3 is an all aluminum mini LS with DOD. I want one. The LS swap kit should bolt right up.
Re: GM's new V6 is finally out.
Post  Lemming on Wed Nov 27, 2013 8:02 am
The 6.2L version looks interesting cyclops  [You must be registered and logged in to see this link.]
Post  xschop on Fri Nov 29, 2013 2:53 am
I would do the 6.2 if I had a 930 trans. I've been in a 6.0 948 locally and even the 951 trans is not good in 1st with that amount of torque. The 5.3 is max for me in 44/
Post  zeusrotty on Fri Nov 29, 2013 10:33 am
Yeah, with my LS3 the shift from first to second sucks.
zeusrotty
Post  944convert on Fri Nov 29, 2013 11:13 am
zeusrotty wrote:Yeah, with my LS3 the shift from first to second sucks.
What's it like if you just start in 2nd gear?
Post  acorad on Thu Dec 05, 2013 11:58 am
944convert wrote:What's it like if you just start in 2nd gear?
I do it at least 50% of the time, works just fine.
Post  zeusrotty on Thu Dec 05, 2013 2:02 pm
It's fine. I can do it all day long. Tons of torque.
zeusrotty
Post  87-944S on Thu Dec 05, 2013 8:48 pm
That is a slick little engine, I don't need one, but I want one too!
Post  dbailey1234 on Sat Dec 07, 2013 9:20 am
Hey so just to add on, I was thinking about doing a LFX swap in my 944. I hear it has a lot of the same bolt patters as the 3800. Any thoughts?
dbailey1234
Post  xschop on Mon Feb 09, 2015 11:23 am
Sorry for the really late reply. I think the LFX is a great engine as well. In the 944, you would probably need a hood scoop/bump, but there are no headers to deal with. I will do another 944 swap and will try to find an LV3 engine out of a wrecked truck. From the pics, the log manifold on drivers side looks like the perfect exit spot to clear or be easy to mod past the steering shaft...and the hood will close.
That said, if anyone wants to do an LV3 V6 swap, I will work with them to get the adapter plate/pilot bearing adapters made, just let me know.
Post  sharkey on Mon Feb 09, 2015 7:05 pm
the lfx being a 60 degree v6 is going to be a tall engine. the integrated exhaust manifolds have they benefits for fitment, however kills any thoughts of improving performance with a pair of headers. power specs look pretty good, and im sure there is more left in the ecm with some tuning. if i were going to do something like that id wait for the twin turbo version, this one might be a little unforgiving with boost at 11.5:1. direct injection allows for higher static compression with boost, but not that high.
im kinda torn up on the lv3. looks like an ls with 2 cylinders missing. the old 4.3l was basicly an old school 350 with 2 holes cut off, and as good as the 350 was, the 4.3l was terrible. its going to be too tall to fit with that intake manifold, and there never will be a car version to bolt to it, so a hood bump is the only option. i dunno, i think there are better options than this engine, imo, the only good reason to swap it in is it would bolt up with the current ls swap stuff, im sure the ls swap mounts would even work.
Post  xschop on Tue Feb 10, 2015 7:40 am
Hood bump or not, this V6 is potent and clutch parts and replacement parts won't cost an arm and leg. The only unknown is the pilot bearing and crank end dimensions. The C5 bell housing bolts right up.
New GM V6
Post  577nitro on Mon Feb 29, 2016 3:24 pm
Did this link die?? I am returning to 944s and want to put either the LLT or LFX into it. I previously had a Renegade kit for my LS. went well, sold it several years ago............Is anyone one making parts for this swap?
577nitro
