Corvette crank pulley
Hi Guys
I am using a '95 Corvette LT1 for my conversion and have found that the crank pulley protrudes further from the engine than the Camaro one does. Can I change pulleys or is the Corvette pulley longer for a good reason? If I can’t change pulleys I will need to set the alternator further forward to line up.
Also has anyone used the Corvette accessories bracket so the alternator is then on the right hand side of the engine looking from the front?
Thanx
Q
Thanx
Q
Re: Corvette crank pulley
I have a hypertech lt1 crank power pulley that I do not need, I'd be willing to let it go for cheap...if it doesn't solve your problems you can send it back...if it works out, you can PayPal me.
admiralkhole- Posts : 62
Or better yet, we can compare measurements.
I used the corvette pully with this bracket (You'll need a new CS130 alternator with this bracket), but I have manual steering and no ac.quarterflash wrote:Hi Guys
Thanx
Q
