Short Shifter
+3
Oso
7 posters
Short Shifter
Hey, anyone using or know of a good short shifter that can mount a universal momo knob to it? All suggestions appreciated. Thanks
Oso- Posts : 28
Re: Short Shifter
All short shifting duties lie with the transmission linkage.
Dawgz83948- Posts : 603
Re: Short Shifter
An aftermarket shift knob is going to be in my future too. As far as i know the only way to do it is to cut the stock shifter and weld on a bolt with the correct threading. That's how i'm going to do it, at least...
Re: Short Shifter
What's the thread and pitch for the Momo Knob? If Any.
Anybody tried this guy out?...
I've been trying to hunt down the threaded ball shaft that fits the 944 shifter pocket, would make things alot easier.
Re: Short Shifter
Hmm, never seen that before! Looks nice, but also about 20x as much as i care to spend for that kind of thing.
Re: Short Shifter
I'm going to build mine with a tapped thread for the common aftermarket screw-in knobs.
FOMO...lol
FOMO...lol
Re: Short Shifter
Lol thanks guys. and ya $200 is pretty high up there... it would be nice though. Maybe I'll just forget about that ssk and do what Porch said.
Oso- Posts : 28
Re: Short Shifter
Grind the shift lever down to the proper width to allow it to be tapped to the desired thread pitch for the shift knob. Its a bit tricky to get the dye started, but ultimately it worked just fine.
That's what I did for the knob on my 924 with the dogleg transaxle:
You could also the stock lever off and weld a new threaded rod in place.
turboswede- Posts : 8
Re: Short Shifter
You can also get one of these. They were $12 when I bought mine, but it works well with the Mono knobs.
Edit: I should know to check the date on the original post.
haroldk- Posts : 140
» Short Shift Kit
» A real short shifter....
» Still pulling away like a freight train supercharged 944 LS1
