Cruise control question
I recently completed the build on my 86 turbo and was wondering if the cruise control should still work after the swap. I have it hooked up and it will accelerate, but it doesn't hold speed. I have checked the brake switch and clutch switch and they seem to be working. I was wondering if there was something I was missing.
jonb944- Posts : 8
Re: Cruise control question
The cruise control is a stand alone system. It reads the speed from the Speedo at the gauge, from there it is processed through the cruise control module. If there is a problem it's either the module or the servo under the hood. It might be a bad switch but I would not think so.....
» Cruise Control.. 928 LS1 Swap
» Want to trade my non-cruise Stalks for Cruise Stalks
» Climate control unit
