» Magnuson supercharged car?
» WTB: LS powered 968
» Poly engine mounts melted
» Intake choice
» JP's LS1 Conversion
What does it take to get the 944 turbo trans in a na car?
Post  DrBoost on Thu Oct 31, 2013 2:08 pm
I've been reading the posts here, and talked with the previous owner of my car (he started the conversion) but have a few questions.
I have an 84 944 with the LS1 in place. I don't expect to do much more than LS3 heads, mild cam, and LS6 intake, so we're not talking insane power levels here. I (think) know that the best bang for the buck is just using a 944 turbo (951?) trans with the 5th gear from my N/A car. My question is this:
Will it bolt right in or do I need do do some fabbing?
Do I need the subframe?
The previous owner said the car has turbo front suspension, but stock rear suspension (but turbo calipers). And for that reason, it has rear spacers to match the front track. Should I get the 944T suspension or something aftermarket (I do NOT want the spacers).
I think that's it. And thanks for helping.
DrBoost
Re: What does it take to get the 944 turbo trans in a na car?
Post  Admin on Thu Oct 31, 2013 3:36 pm
Clarks garage has a good write up on removing and replacing the transmission.
My instructions would be
Remove old NA transmission
Install new Turbo transmission.
Clean up......................you're done!
Trans swap
Post  simon123 on Thu Oct 31, 2013 6:42 pm
Make sure that your NA trans has the tall 5th, I swapped mine (1988) into a Turbo trans only to find out that I had swapped like for like. Check you NA trans model number against the ratio charts.
Tall fifth needs to be 27/37.
simon123
Post  DrBoost on Thu Oct 31, 2013 7:52 pm
Thanks admin.
Simon, where's this chart you speak of?? Sounds like something I need to know before I start the work.
Thanks to both of you.
DrBoost
trans chart
Post  Tehone on Thu Oct 31, 2013 9:32 pm
This may help you on the gearing ratio. This is also from Clarks garage.
http://www.clarks-garage.com/shop-manual/trans-04.htm
Hope it helps.
Tehone
Ratio's
Post  simon123 on Fri Nov 01, 2013 9:33 am
My 88 NA had the 35/29 5th which was the same 5th gear ratio in the Turbo LSD Trans I acquired.
You also need the special splined wrench to undo the big bolt. There is a DIY article on Clarkes.
I have obtained the correct 5th gear and intend to change it in the car. Will post details (cutting spare wheel well) when it happens.
simon123
