Today at 6:41 pm by 962porsche
Yesterday at 10:58 pm by 948
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
What oil do you use?
Post  quarterflash on Sat Oct 26, 2013 9:00 am
Hi Guys
What oil do you use in your LT1 engine and do you put different grades in the winter or summer?
Thanx
Q
quarterflash
http://porschevy.co.uk/
Re: What oil do you use?
Post  948 on Mon Oct 28, 2013 11:26 am
I use any group IV or V synthetic even a group III/IV blend like M1, 5W40. I also add a little ZDDP.
I don't change weight for the seasons; temps run from the 20's to 90's. I completely rebuilt my engine to stock bearing clearances and I have a HV oil pump, PH8 oil filter and a stock 951 oil cooler.
What is the state of your engine?
Paul
Post  quarterflash on Mon Oct 28, 2013 11:41 am
Hi Paul
The engine has done 60,000 miles and I will be using Penzoil Platinum 5w30.
Thanx
Q
quarterflash
Post  948 on Tue Oct 29, 2013 11:59 am
quarterflash wrote:Hi Paul
Thanx
Q
PP is a well respected group III synthetic.
If you want to determine how well your oil & engine is doing have an oil analysis done at each oil change.That will tell you if your oil and change intervals are suitable.
