» NDog52's 1986 NA 5.3 Build
Mounting BMW Hydroboost  EmptyToday at 11:30 am by Gutterboy
Mounting BMW Hydroboost  EmptyYesterday at 6:12 am by Colibri Green
Mounting BMW Hydroboost  EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
Mounting BMW Hydroboost  EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
Mounting BMW Hydroboost  EmptyTue Mar 26, 2024 8:49 am by 948
Mounting BMW Hydroboost  EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
Mounting BMW Hydroboost  EmptyWed Mar 20, 2024 1:17 pm by Rob44
Mounting BMW Hydroboost  EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
Mounting BMW Hydroboost  EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
Mounting BMW Hydroboost  EmptyTue Mar 12, 2024 12:12 pm by ndog52
Mounting BMW Hydroboost  Empty Mounting BMW Hydroboost
Post  jpkinerk Tue Oct 15, 2013 1:39 pm
Working on figuring out the best way to mount everything to the firewall. I saw several threads about the mustang unit and the firewall plate used for that, but what about the BMW system? I'm assuming this also needs to be angled at 12 degrees as well? I know some people have modified the stock cereal bowl, but i looking at adding a firewall reinforcement plate that allowed the BMW hydroboost system to mount directly to it.
jpkinerk
jpkinerk
Mounting BMW Hydroboost  Empty Re: Mounting BMW Hydroboost
Post  87-944S Tue Oct 15, 2013 3:14 pm
Same angle is required, I modified the cereal bowl, but if I did it again I'd just make a plate and build in the angle, probable take less time. Good luck, post pics of what you end up doing!
Post  Techno Duck Tue Oct 15, 2013 3:19 pm
It may take some modifications to work, but i have one of XSChop's hydroboost mounting plates i ended up not using. The adapter on it is for a Ford Hydrboost, but might be possible to make another plate to fit the BMW unit. Let me know if you may be interested.
https://944hybrids.forumotion.com/t1689p30-hydroboost-mounting-plate#21543
Post  jpkinerk Sun Oct 27, 2013 5:04 pm
Thanks guys, after much debate, I think I'm going to get in on a buddy of mine's CAD project to have one of these made. The idea is to include the 12 degree angle needed for mounting the BMW system along with entending the plate over to the master cylinder for the clutch. Once done I'll share pics.
Getting so close!
jpkinerk
jpkinerk
