» Magnuson supercharged car?
» WTB: LS powered 968
» Poly engine mounts melted
» Intake choice
» JP's LS1 Conversion
Sourcing BMW "H31" Hydroboost Parts
Post  jpkinerk on Fri Sep 27, 2013 8:52 am
Hey guys,
So as many have mentioned, you can occasionally find a complete H31 hydroboost system on ebay and such, but after months of searching I decided to piece together my own. Here is a breakdown of where I sourced the parts from and how much. I'll be using this with the Lexus front calipers and Turbo rears. Also, I did not include the fluid resevoir. I'm attempting to use the f-body pump's resevoir. I've been told there are some issues, but I'm going to give it a shot. Anyway, hope this is helpful.
“H31” Hydroboost System
Diagrams of System:
http://bmwe32.masscom.net/maxf_website/booster.htm
http://bmw8.us/Brake%20Booster%20Rebuild.htm
Accumulator i.e. "Bomb" $108:
(note, this is new part, which is advised because of issues with used ones commnly failing)
http://www.schmiedmann.com/7_series/E32/Spare_parts_brakes-chassi-suspenssion_etc/Brake_parts/page6.htm#8306
Hydraulic Booster $150:
(used)
http://www.data.bmrparts.com/bmwparts/BMW_BRAKE/BMW_34331161772_DO_NOT_SELL_USED.html
Brake Pressure Regulator $300:
(used)
http://www.data.bmrparts.com/bmwparts/BMW_BRAKE/BMW_750iL_4DR_E32_BRAKE_DS_Regulator_73_34331159752.html
Master Cylinder
*use stock 944 master cylinder (bolts directly to booster)
So there ya have it. Not including the cost of lines/fittings I'm at $558, not bad I feel like since a refurb DS regulator can cost that much on its own. Lastly, a question. Where can I find the correct booster to brake pedal arm for this application? Is this a fabbed piece? Thanks all.
JP
jpkinerk
Re: Sourcing BMW "H31" Hydroboost Parts
Post  docwyte on Fri Sep 27, 2013 11:42 am
For me the entire point of using the BMW system is so you can use the Porsche master cylinder and not screw up your brake bias. When you move away from the factory Porsche calipers, you screw up the brake bias.
At that point you might as well use the much easier and cheaper to find Ford Mustang hydroboost...
