Conversion Parts For Sale
I have an adapter plate,c5 bellhousing,pilot bearing adapter,and motor mount uprights for sale. Bought from xchop but since have changed directions on project. Email as I do not check site much. [You must be registered and logged in to see this link.]
billy25us- Posts : 1
Re: Conversion Parts For Sale
OK,
Sorry it took a while, Billy...
I looked at these last week, and took some quick measurements.
The mounts (xschop) are ~3/8" shorter than the LTX mounts. These require
.50" custom engine set-back plates, and the "long" style motor mounts.
May or may not require shimming the mounts...
Definitely need to drop the crossmember.
As far as the BH goes, it is an early C5, and I am not sure about the late C5
clutch / PP clearances inside this BH. I do know the above listed BH is what I am using
on my LT1, and the inside diameter is smaller than the 2-piece C5 BH.
EDIT: At the widest point, the 1-piece BH has a 14.25" inside diameter, but it tapers off
more sharply than the 2-piece BH. I'm thinking an 11.0" clutch...
Here's the "long" style mounts...
And the set-back plates...
gt1scca- Posts : 795
» New Rules! Conversion Parts For Sale - READ FIRST
» FS: Conversion Parts and Fiberglass Parts For Sale
» LT Conversion Parts For Sale
