Metric hard line to JIC/AN fittings
In case anybody is having trouble finding parts to adapt the original fuel lines to AN, I found a source for compression fittings for metric tube to JIC/AN. They're at [You must be registered and logged in to see this link.] and run a bit under $10 with all the parts. I used the light fittings since it's for a pretty low-pressure system. There's a minimum $20 order, so I bumped it up with extra cutting rings.
haroldk- Posts : 140
Re: Metric hard line to JIC/AN fittings
That site is a great resource, I got my fuel line adapters from there, as well as a lot of the A/C fittings and hose I used. I believe Marc A was the one who told me about that site or posted it on the old board, glad you posted about it!
Now thats a good deal I just spent $55 from lindsey racing for one set.
gdopnt- Posts : 127
We were trying to use a flare fitting on the lines, but the steel just didn't want to flare without cracking. I knew I didn't want to pay that much from Lindsey for them, so I was glad I found these folks.gdopnt wrote:Now thats a good deal I just spent $55 from lindsey racing for one set.
87-944S wrote:That site is a great resource, I got my fuel line adapters from there, as well as a lot of the A/C fittings and hose I used. I believe Marc A was the one who told me about that site or posted it on the old board, glad you posted about it!
Yep . . . I have them on speed dial . . . .
marc a- Posts : 170
Speed dial, that is too old school Marc, even for old farts like us!!!
Speed dial!
