I have my start.... 2002 LM7
I finally made the 1st step! I shopped around for months to find a good deal that was close to home. Finally, I came across a 2002 LM7 for $300 and it had 85k miles on it. Now I need your advise on what my next move is. My gear head buddy says I need to strip it and have it baked. I think the miles are low enough that that's not necessary, but would like to hear your guys input. Also, anyone who was done a swap like this I would like to hear what cam you chose, reworked the heads, and so on. I'm not liking to be the fasted car out there. Just want 350+rwh (or around that) and reliability. This will be going in my 1988 NA that just turned 90k. Any advice would be appreciated.
Re: I have my start.... 2002 LM7
Why did you go with an iron block engine?
tvagreene- Posts : 3
I'm at the same stage as you. 87 n/a. Have the engine bay clean and ready for the LM7 I just got.
Trying to get my head around the intake, cam, and the A/C.
I have a similar goal of a reliable swap with 350hp. Maybe we can compare notes-
Jasonscottw- Posts : 125
I picked the motor because the price was right and I'm not looking to make a track car out of it. The weight difference was minimal from what i have read.
I can tell you the conversion and the tinkering after has been a lot of fun for me.
I put an 07 5.3 in mine with "mileage unknown" on purchase.
I pulled the heads just to look around, did a valve job and shaved .020 off, mostly to compensate for the reduced base circle of the used ls3 cam I put in. I have Eric's long tubes with stock ls1 intake and injectors. I'm getting 330 rwhp, but now I want more.
I'm going with a bigger cam and ls6 intake when I get a chance.
For me I was looking to just get it running so I wouldn't loose interest, I wish I did the cam when the motor was out, much easier.
Best tip I have is to get a clutch disk with deep splines and make sure engagement there and in the pilot bearing is complete!
Patb- Posts : 46
Today at 12:47 am by sharkey
