Motor Mounts
Motor Mounts
Got a few sets of the motor mounts done and making more. DOM steel is used with 1.0” I.D. and 1.5” O.D. with solid ¼” wall design. The upper perches are 1.O” machined with 0.5” isolator bolt-thru holes and chamfered for precision fit and strength. The base plate is machined from 3” solid steel round and finishes at ¼” thick also. The uprights are Ball-milled on the CNC for the upper perch insets and the lower portion is then set up on a Bridgeport mill using angle gauges to get the 2 exact angles needed before mating to the base-plate. Then it is angle-drilled for the replaceable ½” mount bolt that’s included with the lockwashers and matching nuts. PM me for details
*****NOTE******
These mount directly to the SBC/LT rubber engine isolators and for LS/4.8/5.3/6.0/6.2 engines require inexpensive Engine Set-Back Plates that Carshop.INC sells (no affiliation)
Here's what I made for my 5.3l....
After welding, everything is double checked for accuracy….No SMS used here....
*****NOTE******
Set-Back plates
these will work nicely and give plenty of front oil sump to rear x-member clearance on the Moroso 20140.
With the plate dimensions I used on mine, I have 1.75" clearance. With these you should still have 1" at the X-member and about the same between driver's head and the firewall.
Re: Motor Mounts
Hey Rob,
Will these setback plates work as well?
robstah- Posts : 352
Re: Motor Mounts
If you slot the isolator holes to set the engine back some. But it is better (easier) just to buy the set-back plates because you need the X-member to Oil pan clearance. BTW, I've got your Moroso pan at the Tig welder being finished up.
