Radiator to crankshaft pulley clearance
Hi all
We're in the process of building and have just installed the RH radiator with its fan. There is only a tiny amount of clearance between the crankshaft pully and the radiator fan. How have you sorted this - a shorter pulley, radiator further forward? All comments approceiated. I have also mailed RH.
Car: 89 turbo, engine:350 LTi, conversion kit from RH.
Thanx
Q
Thanx
Q
Re: Radiator to crankshaft pulley clearance
Hi Q,
I have a 1994 LT1 in my 1983 944 with the RH radiator/fan from a looong time ago. The clearance has been fine. Maybe your engine is more forward or the their radiator is thicker now? Or, like you said, maybe you can move the radiator more forward? Also, my '83 may be a little different up front than your '89 turbo. I'll measure the thickness of the radiator and take another picture for you next time I'm under there.
Here's a picture of the space between the crankshaft pulley and the fan motor (yes, the water pump is blown so there's fluid everywhere. In the process of fixing it now ):
RobotMachines- Posts : 165
My radiator is out, have some pictures you may be able to use...
Thanks RobotMachines, I'll compare the gap with my installation although I am expecting it to be the same.
Regards
Q
Regards
Q
» Corvette crank pulley
» Gen IV 5.3 Crankshaft, LS1 Flywheel/Pressure Plate. Detroit
