» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
Water pump seal blown, first tow ever.
Page 2 of 2 Previous  1, 2
Re: Water pump seal blown, first tow ever.
Post  RobotMachines on Mon Sep 30, 2013 12:00 pm
It's only been a month since I last worked on it Rolling Eyes but the water pump is now in...
RobotMachines
Post  RobotMachines on Thu Oct 03, 2013 10:21 pm
Thermostat and power steering pulley done.  I'm the quickest repairman in the northeast!  I can't wait (well, obviously I can a little bit) to finish this in order to run the car for a bit, after a couple of oil changes, and then do a dreaded compression test.  Ran fine after the over heating before I ripped it apart.  Hope it really is ok; no water in the oil, nice compression.
RobotMachines
Post  RobotMachines on Sat Oct 12, 2013 1:10 pm
-944hybrid blog post 1 trillion-
Three days of running the car after driving for probably 2 to 3 miles without coolant.  Only thing saving anything was a large oil cooler and synthetic oil.  After a new pump and fluid changes, the oil is now still sparkling clean, radiator fluid is clean, no leaks, exhaust smells, well, smells like normal exhaust, some sulfur, moist stink, normal, no smoke.  All is clean and is running just like before.
Going to wire up the old Dakota Digital radiator fan controller and take it for a spin.
Compression check to come.
RobotMachines
Post  RobotMachines on Sun Oct 13, 2013 5:05 pm
Scare over, the p-car is running as powerfully as ever...
RobotMachines
