» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
Water pump seal blown, first tow ever.
Page 1 of 2 1, 2  Next
Post  RobotMachines on Sat Aug 03, 2013 10:05 pm
Well it was bound to happen.  First towing of the 948 because of a blown water pump seal.  Driving on the highway coming home from work and I started smelling a burning smell.  Thought it was the car up in front so switched lanes.  Still a smell... then the realization, "it's me!".  Pulled over and once the car reached idle for a few seconds, it died.  The oil was so hot and thin, the pressure went too low at idle and the computer shut it off.  Same thing happened to me years ago when the oil pressure sensor wire was loose.
I use an oil cooler and always use synthetic oil so I guess it may have saved the car from any damage. Hope a head isn't cracked or something.  Once the car was home and it had cooled, I added some coolant.  It started right up as always and ran fine.  I'm about to start researching what I need to take out to change the water pump.  I'm guessing an OEM pump is probably the best option since I haven't had any cooling issues even in the hottest of weather (90s) stuck/crawling in commuter traffic.
Here's a picture, you can see it's been leaking for a little while (look between and past the area between the pulley and fan... wet dark spot on the pump).
RobotMachines
Re: Water pump seal blown, first tow ever.
Post  948 on Tue Aug 06, 2013 12:00 pm
James,
Rock Auto has Bosch pumps for a good price. Grab a set of Fel-pro gaskets too.
Where have you been?
Post  RobotMachines on Wed Aug 07, 2013 8:41 pm
948 wrote:James,
Hi Paul!  Glad to see you around and glad to hear you recommend the Bosch pump because it's the one I bought already.  It comes with gaskets though so I didn't buy any.  Think I should?
948 wrote:Where have you been?
I took up the hobby of trying to figure out what's going on in the world.  Being inquisitive and having a very open mind, like we probably all do in this forum, I think I've reached the point where I need to stop trying to figure out what's going on.  As Monty Python would say, "Run away!  Run away!"
So, back to building and fixing stuff.  I've have the four bolts out that hold the pump in and have the hoses off.  I'm at the point of trying to take the pump out but have a feeling I'll need to remove the radiator to do so.  I'm wondering how far the pump needs to move forward for the cam-coupling to come off.  I'll find out soon.
Picture before I took the hoses and bolts out...
RobotMachines
Post  944-LT1 on Wed Aug 07, 2013 9:14 pm
Hey James!
I remember always having to take the radiator out so I could get the WP out so I could get the opti out. Laughing
PS... The ol' 3 amigos in one thread....like old times!
Post  RobotMachines on Wed Aug 07, 2013 9:23 pm
Michael, hello!
944-LT1 wrote:Hey James!
That seems like it'll be the case.  I may take my headers out while at it and weld some plates on them to cover the cracks and to reinforce them.
944-LT1 wrote:PS... The ol' 3 amigos in one thread....like old times!
As rare as a 948  Wink
RobotMachines
Post  87-944S on Wed Aug 07, 2013 10:05 pm
You guys were an inspiration to me way back, many moons and web boards ago, an still are! I am also glad to see you back James. How is your back holding up on those CT roads with the stiff springs? Very Happy
Mike
Post  948 on Thu Aug 08, 2013 11:49 am
RobotMachines wrote:I've have the four bolts out that hold the pump in......
There are 6 bolts holding the LT water-pump on....are you missing some? That might explain the slow leak. Shocked
Post  948 on Thu Aug 08, 2013 11:57 am
RobotMachines wrote:It comes with gaskets though so I didn't buy any.  Think I should?
If they are the one piece paper type I smear a thin layer of waterpump RTV on both sides before installation.
Post  RobotMachines on Thu Aug 08, 2013 2:45 pm
87-944S wrote:You guys were an inspiration to me way back, many moons and web boards ago, an still are!  I am also glad to see you back James.  How is your back holding up on those CT roads with the stiff springs? Very Happy
Mike
Thanks! Wish we had all of the posts and pictures from Doug's 560sec site to share on here. Lot's of good stuff.
Back is fine so far but my brain cringes when I hit a certain ridge on the highway every day driving it home. The ridge makes the rear of the car bounce out just a little. ouch.
RobotMachines
Post  RobotMachines on Thu Aug 08, 2013 3:05 pm
lol Well, guess I have two more to go then.  I was just preemptively undoing things prior to this weekend.  Just looked at the picture of the pump and see the two extra bolts I missed, they're the shorter ones on each side.  Can't wait to see what may be in the way of getting those out, hopefully nothing.  Just checked and my new pump is waiting on my doorstep for when I get in.
I think I have two types of gasket sealants sitting around somewhere.  I'll compare them to the one from your link.
RobotMachines
Post  RobotMachines on Thu Aug 08, 2013 9:38 pm
Woo hoo!  New pump.  alien
EDIT:  My pump that died just about a week ago, that this one will replace, was the original that was on the '94 LT1 when I bought it from a wrecking yard a long time ago, not bad.
RobotMachines
Post  87-944S on Thu Aug 08, 2013 9:46 pm
Wow, that's one complicated looking pump! I like the grill look on the front though. Very Happy
Post  RobotMachines on Thu Aug 08, 2013 9:49 pm
That grill look adds at LEAST 10hp.
That complicated mess of ports where, eh hem, one needs to be just corked, adds at least another 5HP Very Happy
RobotMachines
Post  87-944S on Thu Aug 08, 2013 10:28 pm
I read that grill adds 12HP, with the port plugged a 17HP advantage! Now, ship that back, and dig in your wallet for a Mezier electric pump! Or, just put an LS in there!Laughing  Glad to see it is easily fixed, and you will be back on the road soon. I want to see a second gear burnout video at 25MPH Very Happy !
Post  948 on Fri Aug 09, 2013 7:05 am
If you plan on using this car as a dd, which i know you do, don't get an electric water pump. They don't put out anywhere near the required amount of real GPM.
Post  87-944S on Fri Aug 09, 2013 11:07 pm
Thanks Doug, I haven't heard that before, but my comment was more tongue in cheek than serious. Very Happy
Post  948 on Fri Aug 09, 2013 11:48 pm
87-944S wrote:Thanks Doug, I haven't heard that before, but my comment was more tongue in cheek than serious. Very Happy
Laughing Who is Doug? Laughing
I understood what you meant......its just that I have gone through the time and expense of trying an electric wp. Don't want anyone else to go through that.
Paul
Post  RobotMachines on Sat Aug 10, 2013 7:35 pm
Yar.
I'll stick with the OEM style pump since it worked perfectly for so long.  I'm not an engineer, but I'd have to say that with an overflow reservoir just a little bigger and about 2" higher, the RH radiator and Spal(sp) fan is perfect for the LT1 and I bet for the LS(n).
EDIT: ... for a daily driver.
RobotMachines
Post  87-944S on Sat Aug 10, 2013 8:59 pm
Sorry Paul! I guess posting that late at night is not a good thing. Embarassed Which pump did you try? I always wondered if an electric would be a benefit. I really hate how ugly the LS water pump bell is, I haven't located anything to replace that fugly pulley.
Post  948 on Sat Aug 10, 2013 9:53 pm
I have the CSR pump, but they are all the same really....
Post  suboptimalfit on Sun Aug 11, 2013 11:11 am
DOUG was OUR fearless leader back '05 ish or so...
this is all his fault-Very Happy
suboptimalfit
Post  RobotMachines on Fri Aug 16, 2013 11:49 am
suboptimalfit wrote:DOUG was OUR fearless leader back '05 ish or so...
yup Very Happy I was looking to convert my 944 to an electric motor.  Then I found Doug's site and purchased an LT1.
RobotMachines
Post  87-944S on Fri Aug 16, 2013 8:54 pm
For the fugly pulley, replacing it with an Edelbrock unit, just because it annoys me. Very Happy
It does requires an adapter for the 4 bolt mounting screws. Waiting on the adapter to arrive.
Post  RobotMachines on Tue Aug 27, 2013 8:53 pm
Radiator is out.  One of the bolts on the pump is loose but not spinning any easier.  I'm getting nervous.  Shocked I let it be for the night and am going to try a few more twists tomorrow.
You can see a hose number, I left that there years ago for reference. NAPA Part#8443
I think that hose fits perfectly (RH radiator and 1994 LT1), no cutting needed.
RobotMachines
Post  RobotMachines on Sat Aug 31, 2013 9:44 pm
Got the water pump out.  Besides the radiator, had to take the power steering pulley off.  Something tells me that we are not supposed to see the ball bearings on the backside of the water pump, eh hem. Rolling Eyes
It did last almost 19 years though. Glad my Opti is sealed and am using the Delteq.
RobotMachines
