Today at 12:30 pm by sharkey
Today at 8:54 am by Rich L.
Yesterday at 5:04 pm by AMFCSL
» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
oil pan pick up pipe
Post  quarterflash on Wed Jul 10, 2013 6:10 am
Hi
I have a 95 corvette 350 LT1 and the RH custom oil pan. It would appear that the oil pick up pipe needs to be altered or replaced to prevent it fouling on the pan. What is recommended in this situation?
Thankx
Q
quarterflash
http://porschevy.co.uk/
Post  fliermike45 on Wed Jul 10, 2013 7:22 am
Re: oil pan pick up pipe
Post  quarterflash on Wed Jul 10, 2013 7:28 am
Thanx for the reply. My garage may just modify the stock item so that it doesn't foul but certainly Moroso are an option. Thanx for the suggestion.
quarterflash
