LT1 Overheating!!!
+3
v8944
kelleysj
7 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: LT1 Overheating!!!
948 wrote:I assume that the "Hot fluid return" is the tee on your upper rad hose? If so, then yes that and the steam vent coming from the rear of the heads should run to the rear nipple on the reservoir. Obviously the tee output in your upper hose should face directly up and be as high as possible to help remove air from the radiatorkelleysj wrote:So the small nipple that runs from my hot fluid return and the steam vent both tie into the expansion nipple?
Thanks 948 and everyone else i was a little lost.
kelleysj- Posts : 194
Well I'm guessing the summit radiator sucks in humid Indiana weather. I had more overheating only difference was I the temp and it decided to spew any suggestions on a better radiator?and will the LT1 radiator work?
Page 2 of 2 • 1, 2
Page 2 of 2
