Clutch pedal clevis
Clutch pedal clevis
I don't know if the 944 is the same as the 968 clutch pedal as mine is and for the life of me can't figure how to get the shaft out of the pedal. It doesn't help there's no room in the footwell and I'm claustrophobic and large too.
Jim7- Posts : 51
Pedal access
If the fuse/relay box is the same on a 968 as a 944, remove its lid and unscrew the two large plastic hand screws, lift the whole panel out and wedge it to one side with a piece of wood, The pedals are underneath.
simon123- Posts : 125
Re: Clutch pedal clevis
You could remove the steering wheel; one wire that just pulls out for the horn, and one nut. ('83 944 here).
RobotMachines- Posts : 165
