Fuel filter fittings?
Hi all, I'm getting a stumble under load so I'm replacing the fuel filter.
Can anyone tell me what these three fittings are that are sticking out of the Corvette filter?
Can I get them an auto parts store?
Thanks!
Andy
Thanks!
Andy
acorad- Posts : 697
Re: Fuel filter fittings?
After googling around a lot I think the fittings are pretty common quick connect fittings?
acorad- Posts : 697
You can get them at most parts stores. Try to find the metal ones, some are a nylon.
Thanks Anthro, will do.
acorad- Posts : 697
