944 turbo radiator switch bung size?
Anyone know the bung size on the thermo switch for the 944 turbo radiator?
zeusrotty- Posts : 444
Re: 944 turbo radiator switch bung size?
Radiator Auxiliary Fan Switch
Catalog No: G5030-21930/WAH and Porsche PN# 823-959-481-F-75-M2 $10.00
Range: 82-77°C (180-171°F)
Awesome! Thank you!
Another question.
My car is currently in pieces. I didn't build it but I'm redoing everything to make it right. As far as the whole cooling/fan switch/rad goes... How do I know if the fans were being run off the stock fan switch or off the ls1 computer? Anything that would stand out without having to hook everything up? The reason I'm asking is I'm not really sure if I need the bung for the fan switch or not.
Im not sure. You could wire it either way but, for example, my LS engine required a pulse width module to run the fan which was pretty costly. Its far easier/cheaper to run the fan with a radiator mounted switch. But, its probably best to wire it as the factory did. If your car came to you with the radiator switch wired up, it probably ran off the switch rather than the computer.
Other than that, trace the wires from the computer or from the fan.
» ls1 to oem turbo radiator hoses
» O2 sensor bung location
» Using 944 N/A fans/need fan wiring/switch help
