» ecotec swap
Yesterday at 4:53 pm by Hotrodz of Dallas
» New 944 widebody & aero
Fri Mar 16, 2018 7:20 pm by scryfst
» Wilwood MC on it's side
Fri Mar 16, 2018 7:09 pm by scryfst
» V8 Conversion Parts
Wed Mar 14, 2018 12:15 am by Chaxce
Tue Mar 13, 2018 11:46 pm by Red944ls1
Mon Mar 12, 2018 8:32 pm by Patb
» Fuel pump options
Mon Mar 12, 2018 12:05 am by V8it
Sun Mar 11, 2018 10:56 pm by V8it
» Poly engine mounts melted
Sat Mar 10, 2018 1:11 pm by acorad
» JP's LS1 Conversion
Sat Mar 10, 2018 11:48 am by docwyte
March 2018
Instrument question
Instrument question
Post  fliermike45 on Fri Jun 07, 2013 10:20 am
My 88 944 Instrument cluster has a problem, Speedometer works OK but the odometer and trip do not work. Rev Counter does not work, what's common here??? Fuel/temp/oil and volts all work OK.
Everything did work OK at the completion of the swap.
Pressing tho odometer reset causes the odometer digits to twitch.
Re: Instrument question
Post  Rich L. on Fri Jun 07, 2013 12:16 pm
My odo and trip are the same. It's a common problem with the little plastic gears in there. I bought a replacement gear but have yet to take things apart and try to fix it.
Post  gdopnt on Fri Jun 07, 2013 7:42 pm
I replaced the gear in my 86. the hardest part was being careful with the old plastic parts. Clark's garage pretty much explains it as it happens. Make sure the reset pad goes back in the same spot. The reset button in vent hits a pad behind the vent and a push rod resets the odometer electrically. My gear was mush a hard plastic gear over time turns soft and the opposing gear eats it also you are not to reset the odometer unless you are stopped.
Odometer gear
Post  fliermike45 on Tue Jul 02, 2013 7:35 pm
I fixed my speedometer today and followed the Clarkes elect-09 instructions.
My gear was in two pieces and had gone very soft.
