» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
VARIABLE SPEED vs FIXED
Post  Red944ls1 on Thu Jun 06, 2013 8:09 pm
Hi folks,
So I have read much about variable pressure compressors vs the constant pressure. I still dont understand the why of it.
If I am changing the Dryer, and the compressor -- would I need to modify the compressor still.
I am running lines into the bulkhead from the compressor and condenser. Also if changing my dryer -- it looks that I will have to get a switch ?
Red944ls1
Re: VARIABLE SPEED vs FIXED
Post  Arthropraxis on Thu Jun 06, 2013 9:33 pm
If you plan on running the AC using the Porsche switches and HVAC controller the GM compressor needs to be modified to fixed. If you are going to use the pressure sensor off a a GM donor and allow the GM ECM to control the compressor does not need to be modified.
TRUCK AC COMPRESSOR
Post  Red944ls1 on Fri Jun 07, 2013 8:53 pm
I am going with a truck ac compressor and it has what I think is a pressure switch on the back - Since I am going with this compressor would I need to do the modification as in the LS1 Compressor. Could I use this switch?
Red944ls1
Variable pressure
Post  fliermike45 on Fri Jun 07, 2013 9:06 pm
In the F body compressor the variable pressure valve is inside the compressor and retained by a circlip. The connector is for the wiring to the clutch. I'm sure your truck version is similar.
Post  Red944ls1 on Fri Jun 07, 2013 9:26 pm
It is very similar as far as removal -- I have pulled the purple connector out it does not look the same --
Red944ls1
Pressure
Post  fliermike45 on Fri Jun 07, 2013 9:43 pm
Is the truck compressor fixed pressure?
Post  Red944ls1 on Fri Jun 07, 2013 9:58 pm
Thats what I am looking up now -- and it seems that it is.
Red944ls1
Pressure
Post  fliermike45 on Sat Jun 08, 2013 8:01 am
If it is you can use it with the Porsche system without doing any modifications. Control the compressor clutch with the existing Porsche wire. No need to involve the PCM computer.
Post  Admin on Sat Jun 08, 2013 9:22 am
Red,
How do you plan to use the truck compressor? have you test fit it yet? Are you planning to cut the frame rail, the line run right into it!
What bracket are you planning to use? The truck bracket is in the wrong location (belt routing) and the truck compressor will not fit in the LS1 style bracket. (wrong bolt locations)
