» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Colorado Emissions
Page 2 of 2 Previous  1, 2
Re: Colorado Emissions
Post  docwyte on Thu Jul 18, 2013 7:16 pm
I take my car to MAC Autosport in Parker. They also tuned my car and have a 4 wheel drive dyno. They did quite a bit to my car this off season, drop me an email or text and I'll tell you more
Post  rdanford on Wed Jul 31, 2013 12:08 pm
Doc...Thanks for the recommendation of MAC Autosport. Nick did a great job on the retune...the DFCO was turned off and it was running way rich at almost all times. After the retune the car passed easily with DFCO coming on and AFR at proper levels plus I gained 23.5 rwhp.
rdanford
Post  docwyte on Wed Jul 31, 2013 12:25 pm
That's awesome! Passed emissions and gained power.
What did you end up with hp/torque wise?
Post  gertbfrobe on Thu May 29, 2014 5:16 am
Thanks for posting this thread. I'm moving to Denver from Honolulu in the next few months and I'm trying to find out as much as possible about about smog rules pertaining to swaps should I end up with an LS1 candidate vehicle that is newer than 1975, which is quite likely.
So far I've gathered that these points are crucial when it comes to a Colorado legal swap
-All smog equipment that came on engine must be present
-Engine cannot be older than vehicle and cannot come from a different class vehicle
-CEL must function
If anyone have anything to add please do, I'm eager to get a project in motion.
gertbfrobe
Post  docwyte on Thu May 29, 2014 8:45 am
Well, any LS is going to be newer than any 944 chassis, so you don't have to worry there. You need both cats, all 4 oxygen sensors, the smog/air pump and all the readiness monitors need to be set/ready. There are ways to make that happen in the tune, it took me awhile to figure that out.
Then you need to take the car to a referee station first, where they inspect the car to make sure all that stuff is there, then you take it to the smog station where it gets tested...
Post  gertbfrobe on Sat May 31, 2014 10:16 am
Does anyone know if it would be easier to swap in an 04 GTO LS1 than an earlier produced LS1 from an fbody or corvette? I know the GTO LS1 doesn't have a smog pump, is there any other differences that would make it easier or harder?
Also I've heard that swapping an 05-06 GTO LS2 requires the entire fuel system/wiring/and tank from the donor car, is this true of the 04 GTO LS1 as well?
gertbfrobe
Post  docwyte on Sat May 31, 2014 10:52 am
Corvette accessory drive doesn't fit on our car. You either need and F body or a GTO motor. To my knowledge the GTO motors still have a smog pump.
No way you can install the GTO fuel tank etc. On my car I just forced those readiness monitors to read "ready" even tho I still have the original 951 systems in place.
Post  pormgb on Sat May 31, 2014 11:49 pm
gertbfrobe wrote:Does anyone know if it would be easier to swap in an 04 GTO LS1 than an earlier produced LS1 from an fbody or corvette? I know the GTO LS1 doesn't have a smog pump, is there any other differences that would make it easier or harder?
I am going through smog certification in California, it sounds similar to Colorado. The only LS motor with accessories that can meet CA smog is from a Camaro, this is mostly due to Cat location and exhaust manifolds. I have been able to get all smog items installed including a CARB legal K+N air filter. The only questionable area are the Cats, CA smog rules state that Cats need to be within 3 inches of their original location, mine are about 5". I am pretty much ready for the inspection, it has taken me along time due to tuning and obtaining a CEL free motor.
Take a look here;
pormgb
Post  docwyte on Sun Jun 01, 2014 11:17 am
Difference is here they don't care about CARB EO. So you can run whatever headers and intake you want and have the cats pretty much anywhere you want.
You just need to have all the systems from the car the motor came from. So go with a motor that didn't have an EGR system. Then all you need are cats, 4 O2's and a smog pump. Then use HP Tuners to make all the readiness monitors read "ready".
Post  gertbfrobe on Sun Jun 01, 2014 12:57 pm
docwyte wrote:Difference is here they don't care about CARB EO.  So you can run whatever headers and intake you want and have the cats pretty much anywhere you want.
And when you're getting the smog check done no red flags come up as a result of the monitors being forced on?
gertbfrobe
Post  docwyte on Sun Jun 01, 2014 1:22 pm
No, they can't tell. All they know is that all the readiness monitors are set.
Post  pormgb on Sun Jun 01, 2014 7:01 pm
I see, you guys are lucky.
pormgb
Post  docwyte on Mon Jun 02, 2014 8:53 am
It saves a lot of headache trying to fit manifolds, the OEM cats, etc, etc. They have a modicum of logic here, where if the car blows cleanly enough to pass the test with headers and aftermarket cats, they don't care...
