Today at 6:37 am by Patb
» 5.3 conversion on 88 Turbo
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
944 turbo radiator switch bung size?
Post  zeusrotty on Sat Jun 01, 2013 2:50 pm
Anyone know the bung size on the thermo switch for the 944 turbo radiator?
zeusrotty
Re: 944 turbo radiator switch bung size?
Post  944-LT1 on Sat Jun 01, 2013 7:13 pm
Radiator Auxiliary Fan Switch
Catalog No: G5030-21930/WAH and Porsche PN# 823-959-481-F-75-M2 $10.00
Range: 82-77°C (180-171°F)
Post  zeusrotty on Sun Jun 02, 2013 2:09 pm
Awesome! Thank you!
zeusrotty
Another question.
Post  zeusrotty on Sun Jun 02, 2013 2:41 pm
My car is currently in pieces. I didn't build it but I'm redoing everything to make it right. As far as the whole cooling/fan switch/rad goes... How do I know if the fans were being run off the stock fan switch or off the ls1 computer? Anything that would stand out without having to hook everything up? The reason I'm asking is I'm not really sure if I need the bung for the fan switch or not.
zeusrotty
Post  944-LT1 on Sun Jun 02, 2013 6:33 pm
Im not sure. You could wire it either way but, for example, my LS engine required a pulse width module to run the fan which was pretty costly. Its far easier/cheaper to run the fan with a radiator mounted switch. But, its probably best to wire it as the factory did. If your car came to you with the radiator switch wired up, it probably ran off the switch rather than the computer.
Other than that, trace the wires from the computer or from the fan.
