» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Rim Options?
Rim Options?
Post  tylersinclair15 on Fri May 24, 2013 2:50 am
I have a 87 944S. What are my rim options and tire width options with no rub?
tylersinclair15
Re: Rim Options?
Post  marc a on Fri May 24, 2013 10:18 pm
THE PORSCHE 944 "1987-1991" (Including Turbo models) & 968 "1993-1995"
No spacers needed for newer 17"- 18" wheels in the 48 mm-65mm et range. All 986, 996, 997, part# wheels will require a 1/4" (7mm) for the front hub. This is so the wheels will mount flush on the hub. This is needed for all newer wheels. 993 part# wheels will not need the spacer.
Most extreme fitment-Front 18x9 et52mm -Rear 18x11 et65mm
18x8et 50mm and 18x10et 65mm on 1991 944 S2 below
marc a
