Tubular K Member? EmptyYesterday at 11:51 am by geegeesbits@gmail.com
Tubular K Member? EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
Tubular K Member? EmptySun Jan 26, 2020 4:51 pm by j7wolfe
Tubular K Member? EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
Tubular K Member? EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
Tubular K Member? EmptySat Jan 18, 2020 7:15 am by Rothaus
Tubular K Member? EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
Tubular K Member? EmptyThu Jan 16, 2020 2:11 am by Golten1986
Tubular K Member? EmptyTue Jan 14, 2020 2:48 pm by Gumby
Tubular K Member? EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
Tubular K Member?
Tubular K Member? Empty Tubular K Member?
Post  tylersinclair15 on Fri May 24, 2013 1:52 am
Has anyone made a tubular k member so you can use the factory SBC oil pan?
tylersinclair15
Tubular K Member? Empty Re: Tubular K Member?
Post  Admin on Fri May 24, 2013 7:56 am
Yes, and to answer your next question , NO.....
Post  tylersinclair15 on Fri May 24, 2013 12:41 pm
How much did they go for? Not asking for one, just looking at options. That would replace the uprights and shaved pan right?
tylersinclair15
Post  Admin on Fri May 24, 2013 1:15 pm
Price doesn't matter, I only made a few and will not make any more. It's something that you would have to make and design yourself.
Post  tylersinclair15 on Fri May 24, 2013 1:18 pm
Im asking how much I should pay for someone locally to do design one. My fabrication skills aren't great. I'm more of a wiring/electronics guy.
tylersinclair15
Post  Rich L. on Fri May 24, 2013 2:29 pm
Post  v8carreragts on Fri May 24, 2013 4:52 pm
You know that you can use a Milodon p/n 31070 pan? Unless you have a late block with the dipstick on the right side. If you do you need to modify the pan to swap sides like I did.
Post  tylersinclair15 on Fri May 24, 2013 5:09 pm
The Milodon p/n 31070 will fit without modification? The dipstick is on the left.
tylersinclair15
Post  v8carreragts on Fri May 24, 2013 6:38 pm
The Milodon 31070 has a left side dipstick which is 1955-1979. In 1980 Chevy moved it to the right side. I have no idea why. My block is a 1984 so I modified the pan to have the dipstick on the right side. It fits otherwise without issue.
I have the engine upside down with the crossmember and steering rack in this picture from my album.
This pan is about $250 new but I found mine on e-bay for $150. If you have a left side dipstick it should bolt on as is.
Post  tylersinclair15 on Fri May 24, 2013 9:59 pm
Sounds good. Thank you.
tylersinclair15
Post  962porsche on Mon Sep 02, 2013 6:42 pm
moroso has all the spec's to build the oil pans for the 944's swapping in the right side dip stick SBC motors . thay also will build the pans for the left side dtp stick motors . they are a must if you plan on road course racing your car .
they are 6.5 QT's ,baffled road racing oil pans with the needed oil pump and pick ups .
they have built me all the pans for the swaps i do in my shop . call or email moroso them selfs as they are not listed in there part product guide .
962porsche
962porsche
Post  Remy6908 on Thu Sep 05, 2013 5:06 pm
v8carreragts wrote:The Milodon 31070 has a left side dipstick which is 1955-1979. In 1980 Chevy moved it to the right side. I have no idea why. My block is a 1984 so I modified the pan to have the dipstick on the right side. It fits otherwise without issue.
Can the OE oil pickup be used with this pan? If not, do you know what pickup is needed?
Remy6908
Remy6908
Post  spence on Thu Sep 05, 2013 6:20 pm
Post  Remy6908 on Thu Sep 05, 2013 6:40 pm
spence wrote:[You must be registered and logged in to see this link.]
Perfect Thanks!
Remy6908
Remy6908
Post  matt889 on Sun May 31, 2015 10:46 am
looks sweet !
matt889
